- 24 Sep 2013
- Exmouth, Devon
39hrs and just got bored of the repetitiveness. May finish it one day.
It seems the update has killed the game for me. It no longer loads and keeps telling me its 'flatlined'
Solution was found after scouring online, disabling saves, verifying files, reinstalling, updating gpu drivers, removing overclocks from cpu and gpu, killing discord steam and praying to the Lord.
So there is this NahimicService on your system, associated with audio drivers, can be on Asus, MSI and all.
1. Go to task manager, kill all process called Nahimic from details tab
2. For stopping that repeated task every time you restart disable NahimicService with services.msc
3. You can disable auto start of stuff like Sonic Studio and such apps
Just doing step 1 should allow you to launch the game now.
Good luck and let me know if I helped you
R's QA team didn't catch this fairly common issue before hand but I'm guessing there'll be a micro-patch along soon to correct it properly.THye've tried to polish the smelly brown thing. Any DLC is just rolling it in glitter.
I'm reading RT is bust after the patch?
Where is this? RT is improved after the patch. We now have RT local shadows where we only had sun shadows previously so FPS may drop slightly as a result of turning on RT shadows since objects now cast RT shadows.
https://wccftech.com/cyberpunk-2077...-on-pc-thanks-to-partnership-with-nvidia/amp/
Still seems to run the same for me with all RT on and where available, set to Psycho.
It's the RT cores numbers that matter most, not the memory clocks on games like this that use RT extensively.
