@crazyDAJT - ah thanks for the clarification
Module 3 and 4 complete, synced these ones with my friend who first told me all about this. We upped the distance to 600 yards in module 3 using both Vernier sights and a scope on a .308 rifle. I was a bit worried with just the sights as I could barely make out the large target numbers (I need glasses) but did fairly well accuracy wise and grouping. With the switch over to 600 yards, we also started using the electronic targets - so much easier. Also learned the basics of wind reading and applying appropriate adjustments.
Module 4 went even further, now 1000 yards and boy was it a windy and cold day. Glad I went first in my group as our electronic target stopped working so we had to stop early by the 4th or 5th person. Again, pleased with my grouping (pic below), though I need to do better at converting wind direction into Minutes of Angle.
Me and the .308 - my positioning isn't great here but think I corrected (needed to be more behind the rifle).
My friend on the .308
Most of the day on module 4 was theory and exams. The first test being an 40 question MCQ, pass rate was 30 (though irrelevant if you got the first question on the 4 safety rules wrong) and I got 35. That was fine but the harder and more pressure inducing test was having to prove we could handle, load and fire 4 different firearms under test conditions:
- AR15 - fine
- Ruger - I just can't get on with this rifle though I know why now. The little latch to release or hold the bolt, most people use their index finger to do so (it is known for being a little janky). For some reason the way mine is shaped, it just doesn't play ball when pushing or applying pressure.
- Marlin - fine
- Misfire drill with a .308 - fine
So I've passed my tests
and 2 more modules to go which are essentially full shoot days I think. The .308 is still my favourite. I like its simplistic and methodical mechanism, feels good and very satisfying landing a good shot so far away. Again, need to work on my consistency, my positioning behind the rifle and sack off the beanbag I initially used for rear support.
Already planning a summer's afternoon on the 1000 yard rang, hire one .308 with my friend and see how many holes we can make in paper.
