Safest place to head is burnley
nothing will make that town go down
Death would be preferable
I’m in an interesting position. If dropped on the centre of London, I’d be right on the edge of the outermost greyish ring on nukemap. Forget what that bit is now.
LinkThis whole situation makes me wonder again what the US was doing couple of weeks back when they pulled something out of Germany, from the airbase nuclear weapons are stored at, under heavy escort with heavy NATO AWACS/ISR missions in the region.
what bomb did you select?I’m in an interesting position. If dropped on the centre of London, I’d be right on the edge of the outermost greyish ring on nukemap. Forget what that bit is now.
From what I've gathered it can intercept Cruise missiles. However, it dosnt have range to have any real effect against ICBM's, the war heads would be in their terminal phase when its in range of Skysabre, and would be next to impossible to intercept.I don't think we ever operated Patriot. Sky Sabre is the replacement for Rapier as far as I know, and is more of a point/local air defence system. I could be wrong but I don't think it has any ABM capabilities.
Admiral Akhbar approves of this post.That's a trap.
LMAO, that's awesome xDNo you are trying to use your last bit as a get out.
I keep seeing this quoted 6000 nukes that Russia has, but having them and then the ability to use them are two very different things entirely. Russia has approx 1500 deployed nukes, the rest are a combination of waiting to be decommissioned, or are in reserve. There are also rumours that their Nuclear program fell into such a state leading up to and after the fall of the USSR, that it is even questionable how many of their 1500 nukes are actually in a good enough state to be launched. To give it some context - since the 1940's the U.S has spent over $5 Trillion on just maintenance of their stock of Nukes. The USSR, & then Russia have had severe financial hardships upkeeping their stock.Not all 6000 of them, I'm no expert - but one would probably hit. Doubt the UK would be the biggest target anyway, not that it will ever happen mind you.
It’s not a vapour zone. I’ve used nukemap before and the outermost ring is not a vapour zoneIm in a bright light vapour zone, think the Terminator playground scene![]()
So to sum up: You read part of a post, claimed it was wrong, then posted the same explanation as a correction. Then when it was pointed out to you that you misread/misunderstood the point and we were arguing the same thing you read the whole thing, realised it was correct when all read together, and then decided the last sentence is just a "get out" because if you ignore/omit that part then the context changes and your original complaint is valid after all. That's just... Jesus lol xD
To be honest, given the state of Russian military equipment we've seen, I don't put much weight behind how many actual ready to launch nukes the Russians have. I don't buy the whole "Russia has only sent in the bad gear to save the good stuff". Given how much egg he's got on his face he would have deployed his 10 good tanks and his 3 generation 5 fighters by now.
Putting is ALL FACE as it's now been proven.
I really hope not but given everything that has happened in the last few days, I genuinely have no idea.Do we think Putin would dare to use battlefield nuclear weapons?
Tbh he only needs a handfulI keep seeing this quoted 6000 nukes that Russia has, but having them and then the ability to use them are two very different things entirely. Russia has approx 1500 deployed nukes, the rest are a combination of waiting to be decommissioned, or are in reserve. There are also rumours that their Nuclear program fell into such a state leading up to and after the fall of the USSR, that it is even questionable how many of their 1500 nukes are actually in a good enough state to be launched. To give it some context - since the 1940's the U.S has spent over $5 Trillion on just maintenance of their stock of Nukes. The USSR, & then Russia have had severe financial hardships upkeeping their stock.
