I had temps like this on my 3600 with the stock cooler.
Changed to a nd15 massive cooler and it barely broke 65 degrees with the fan running slow.
The worst contributor to temperature for me is my 3080ti Fe. The blower cooler adds lots of hot air to the case and I had to increase case fan speed the compensate.
My CPU Cooler is the Arctic Esports Duo, it runs at 0 RPM below 60c.
Ramps up heavily around 75c.
Both the GPU and CPU idle with zero fan.
Also in a small ITX case...
If you would like to help me out: https://forums.overclockers.co.uk/threads/needing-a-cpu-cooler-for-5600x.18948394/
Sounds like poor airflow and small case is the chief issue. My 3600 hits 65c on an aging AIO but that's max. I dont think the cooler you have on the CPU is that bad, would be surprised if the switch netted you much difference from scythe considering how much they will cost.
The issue here probably isn't so much the cooler, but using a Small case, (I did scan but didnt see the case mentioned) you just wont have enough fans to draw enough air through the case for an air cooled CPU & GPU when gaming. Didn't clock which 3070 you have but an AIB will draw and dump the air into the case, and an FE whilst dumping out the back will need a decent feed of cool air. Same as the CPU cooler. Then they both fight for cool air. You can change the cooler to whatever you want but if it's not getting the air from the case intakes and heat exhausted - a different cooler wont make much difference.
Seems identical prognosis.![]()
Missed your comment - apologies. Case is probably listed too![]()
I was scared when I got home and picked the package up, it felt like a feather.. I was thinking, I have been done...I think only 5600X comes with a cooler this gen, my 5800X certainly didn't![]()
Uhm the CPU-Z temp test was with fans on maximum, the 5800x is using the default MSI fan curve.Is it using the same "relaxed fan curve"?
83 is perfectly fine to run at for a cpu especially if you want to heat the room while playing![]()
Under Prime 95 the 5800x hit 87.2c maximum, the 5600x outright fails even with fans on max.
Do me and others a favor and don't forget to read properly. I linked my other thread, there is info in there too.
I am glad I have the Fuma 2 on it's way and my Noctua fans are due today.
Already the 5800x is a vastly better chip in terms of efficiency and cooling, it seems my 5600x is just perhaps not connected correctly from IHS to the die or something.
I mentioned CPU-Z was representative of Crysis 3 temps, just that with the fans on max it cut them by 10c on the 5600x.I don't think running the CPU-Z bench will be the same as 'melted via gaming' as the bench only runs for a short time on the CPU. Gaming will be the one when the GPU is dumping into the case/sucking air in competition with the CPU. You need to run the GPU & the CPU to get the gaming temps.
Haven't seen this in years what a classic. Reminds me of my blower 7950.
That's what AMD cards used to be for.....
I don't think running the CPU-Z bench will be the same as 'melted via gaming'. Gaming will be the one when the GPU is dumping into the case/sucking air in competition with the CPU. You need to run the GPU & the CPU to get the gaming temps.
