Was that new or second hand?
New from wiggle. Crc were same price too. 295 then 10% off code.
They arrived in a clear bag inside box. Brand new.
160 travel boost RC.
Ill put a charger 2.1 damper in eventually
Not considering selling the Bizango are you? Or is it needing a lot of love?My Voodoo Bizango has done fantastically over the last 3 years but now time for an upgrade, isn't surviving bike park days anymore. Pretty sure will be a Bird AM9 but wondering if there is anything else out there for under £3500 that would be worth demoing? I have completely ruled out Whyte as everyone i know that has bought one recently has had no end of issues with them.
Wiggle and CRC are the same people which is why their prices are identical.
I know they are the same firm but funnily enough they won't price match each other when they have price discrepancies. I had a chat with their customer service about why body armour on crc was cheaper than it was on wiggle. Yet wiggle had the size I wanted listed in stock. The guy on wiggle refused to match crc price on the item and I had to wait weeks for them to line up.
Well thats just bizarre
I have never found any product that isn't perfectly mirrored between the two sites personally but I generally use CRC because I feel like the site is just a bit easier to use.
2022 forks? I saw them and almost boought from them but got a pair from bike discount instead. Maybe its was just the image on the site but they looked like 2020 forks going off the decals. Also got a tyre from bike discount with was another reason for buying from them. They won't post to the UK unless you spend more than £176! Thanks a lot brexit![]()
My plan was to put in a charger 2.1 damper pretty much straight away but tbh I think I will wait a bit as I don't think the motion control damper is as bad a people let you believeNot considering selling the Bizango are you? Or is it needing a lot of love?
Tell me about it, still waiting for a frame. At this rate I may as well wait for the next MY version.Yeah, Brexit has been a right PITA. I used to get almost all my stuff from Germany for about 2/3rds the price it would be in the UK. Very annoying, especially coupled with the supply issues for bike parts over the past 2 years.
I like the Hopes for their seal on the lower cup keeps the filth out so much better.So trailbike needs a new headset. I've always gone with Cane Creek as they make nice headset. DH bike bike has a CC 110 and its lovely. But trail have needs an IS42/IS52 headset and was thinking maybe giving hope a try. Partly because its a little cheaper and party because they are made in the UK it might handle the mud and slop better...? maybe? Anyway would you get a Cane Creek Hellbender 70 or Hope headset? CC is £75 and hope with pick n mix cups to £60-65 i think.
what's the bike? I had a "lot" of fun changing the headset on my 2017 carbon YT Jeffsy and that's listed as IS42/52 too.So trailbike needs a new headset. I've always gone with Cane Creek as they make nice headset. DH bike bike has a CC 110 and its lovely. But trail have needs an IS42/IS52 headset and was thinking maybe giving hope a try. Partly because its a little cheaper and party because they are made in the UK it might handle the mud and slop better...? maybe? Anyway would you get a Cane Creek Hellbender 70 or Hope headset? CC is £75 and hope with pick n mix cups to £60-65 i think.
I'm trying to remember the details and will try to go through emails and purchases to see if I can remember what went wrong...
my year's Jeffsy came with an Acros is42/52 and over the years I'd gone through a couple, so I thought I'd spend a bit more and go for a "better" make, so went with a CC Hellbender 70...
BUT... for some amazing reason... the CC is52 bearing is only 6.5mm thick (Acros is 7mm) - this meant the fork hit the bottom of the frame when it rotated... So, I had to knock off the fork's crown ring and fit a 0.5mm shim/spacer under it (at the time I spotted that CC even sell an elongated crown ring, presumably as enough other ppl get this problem with their thinner bearings - but it wasn't available at the time).
So, now I had the bottom bearing sorted, ace... But, it wasn't the end of it...
Top bearing in and no matter what I did, I couldn't get it to sit nicely. The only way to remove play was to crank down the topcap so tight the steerer wouldn't turn... So, I pulled it apart and had a look... Again, the bearings sat too low, so I had to find some more shim spacers - what a surprise, CC offer these too: https://www.amazon.co.uk/Cane-Creek-Inch-Headset-0-25/dp/B005MK3ZXM
I emailed CC a few times with all these issues and they said it was a known issue for Specialized bikes, so they'll add YT to their list... This was in Jan '21 and funnily they've now got a FAQ about this dated Feb '21: https://canecreekhelp.freshdesk.com...how-and-when-to-use-shim-spacers-for-headsets - I honestly wasn't impressed that a premium headset didn't come with those shims (especially when they admit it was a known issue for some v popular makes).
I found I could now ride, but after a couple hours on the bike I could hear a knock - then a bit more I could feel some slight play... Something wasn't right. I can't completely remember the issue though - I think it was something to do with the angled contact faces on the CC bearing - I seem to remember it being a fancy design with 2 angles, one for 45° and another angle for a different spec (guess 36°?) - either way, it resulted in a tiny contact area in my frame and not enough to sit nicely. So ended up buying a 42mm Ritchey WCS Headset Bearing as an experiment (and it was a fiver) and it fitted solid and worked with the CC headset and not looked back since...
moral of the story - CC heatsets are a mess with the older design carbon Jeffsy... (and would have saved half the cash, and about a month of messing about, by going back to Acros again).
Hey up. Wondering if anyone can recommend a budget fork for my calibre two cubed?
It's a 27.5 9mm qr.
What is your budget?
Do anyone run or tried a one by 12 speed setup but with the 45t cassette rather than the usual 51/52t. Got a shimano set up at the mo with 32t chainring and 51t cassette. Thinking of changing the cassette to 10-45t as it needs changing anyway and I never use the 51t sprocket. Second sprocket on my current set up is 45t and thats all I need for everything ive ridden on the bike so far. The way I see it is the 10-45t will be lighter, quieter and shift crisper thanks to closer range.
