Don't go back to HZD after playing thisI jumped right off a tall structure upon loading up my last save and then realised...no glider.
Main quest finished I enjoyed it but not as much as the first. Still have loads to do so will keep me busy for weeks still…..
The melee pit challenge is doing my head in.
R1-R1 pause R1-R1 why is it so hard, I've fluked it one then the next bit is a half moon.
I can do then all in the tutorial but not in the challenge.
Thanks all done now, first Platinum trophy in a while apart from the melee combo stuff was an enjoyable one.Ignore half of what it tells you to do when you're chaining them together. The last R1 of a sequence often counts as the first R1 of the second sequence. I was doing two R1s when you only need one. It's quite confusing.
Also, Aloy's spear glows blue indicating the end of the pause so you should press another button at that point. That's only in certain combos though.
Tip. Go straight for the human and kill him with blast sling rounds (they knock him down so he can’t shoot). Pick up his cannon and kill the ravager with it. I was getting annihilated trying to kill ravager first. I switched my tactic and fight was over in 30 seconds. Worth a try if you are struggling.
Does anyone else think the Horizon games would be better suited to a more linear type game, and not so much open world stuff?
I mean I am loving the game, the story is great and probably the strongest point, it could probably work without all the open worldness
Path 1.07 dropped today which claims to fix some graphical issues. To be fair; I've not noticed the shimmering issue when playing on performance mode.Wish they'd hurry up and fix the graphical issues so I can play this. Good reminder to myself that I shouldn't buy a game on release. Could start Frozen Wilds in the mean time I guess.
