We have our own humanitarian crisis on the horizonIt also highlights, if you want to see it that is, just how hard it will be for those that don't have any "luxury" expenses to eliminate first.
Eat or be warm is a real prospect.
It's interesting to see a fair few comments regarding people dropping "luxury" outgoings to accommodate the price rises. Obvious when you think about it, but it does highlight the hit that the wider economy will take i.e Sky, Netflix etc.
It's not at all.It’ll be much cheaper to get some clothes dryers in front of radiators and use a dehumidifier to keep the moisture in line.
Not if you buy the right one.It's not at all.
Our heatpump dryer for a cycle uses less than leaving the dehumidifier on for a few hours.
https://meaco.co.uk/shop/control/dehumidifiers/meaco-12l-platinum-dehumidifier/A 12l dehumidifier with a rich set of features and a low energy consumption to help reduce running costs considerably.
The Meaco 12L Low Energy Dehumidifier uses just 165 watts of power and this combined with the unique Meaco Control logic provides a very cost effective and accurate solution to dehumidification and dealing with damp.
the number 2 rated is:
Beko DHY9P56VW Which is much cheaper.
Also think about the many millions who go without those luxuries already to get by, what are they supposed to do? Many of us are lucky that we can absorb the cost (at least for now) but the future looks very bleak.It's interesting to see a fair few comments regarding people dropping "luxury" outgoings to accommodate the price rises. Obvious when you think about it, but it does highlight the hit that the wider economy will take i.e Sky, Netflix etc.
We dry ours outside when possible but the rest gets dried indoors. We have a tumble dryer but I can count on both hands how many times I’ve used it. We thought about using it overnight but your washing has to sit in it for a few hours and besides we wash our clothes overnight on economy 7 so it won’t work. We treat a tumble dryer as a luxury or as an emergency drying aid not an everyday appliance.still £550 it seems - fortuntely most of ours dries outside - a better weather app/rain-alarm would be good though.
.. but using radiators+dehumid , unless you have only small amount - no duvet covers and towels - the cost of heating additional rooms too, or heating more, to ensure it dries fast enough to avoid musty for me. running the dryer on overnight rates too - cheaper than additional daytime room heating.
Yeah I think generally heat pump dryers are expensive. For a heat pump dryer, that one is pretty cheap.still £550 it seems - fortuntely most of ours dries outside - a better weather app/rain-alarm would be good though.
For those looking at Heat pump tumble dryers.
If you value Which? Reviews. The number 1 rated is:
AEG T9DEB969C Which is expensive
I have a subscription to Which? So if anyone wants to know the top rated whatever let me know.
@Dirk Diggler
They certainly bring a massive convenience compared to line or inside drying it must be said.Do a compareInteresting.
We bought a new tumble a couple of years ago, the difference in price was well over £200 not £100. I wonder if they are now a lot closer.
I did fall for the "I will hardly use the tumble drier" line when she said she wanted one. I think that was a little white lie.They certainly bring a massive convenience compared to line or inside drying it must be said.
We used to dry inside probably 6 months of the year like many people with full time jobs, and having washing scattered around the house wasn't great I have to admit.
Whilst its not ideal and its expensive heating, we can really tell the difference when the tumble is running, half the rads switch off completely that would be on at least partially in the evenings.
https://media.ao.com/en-GB/energyrating/productdatasheet/mmo_93345027_1631280025_3365_12162.pdf
My wife seems to have a fetish for tumble dryers, refuses to use the washing lines outside or radiators + dehumidifiers. Bought a Hisense Heat Pump dryer a few weeks ago and it's had a noticeable effect on our electricity bill (smart meter + IHD monitoring), just in time for April![]()
I plan to add insulation to the ceiling of the living room its the most occupied.I've been looking at cavity wall insulation but far to many horror stories. Also looked at render with external insulation but apparently doesn't work well with cavity walls.
I think the best I can do is get the house repointed, it's 1960 and never been done so I think would benefit from it.
Having a loft conversion and new roof in August so that's the loft and roof sorted. Not sure what else to look at, I know the windows have PVC trims internally which is covering the gap to the cavity wall, I was thinking of removing the trims and filling the gap with something on all windows because there is a draft coming through but that might cause cold spots and potentially bridge the cavity wall for moisture to travel from the external to internal walls so really don't think there is much I can do, anyone else thought of anything?
Going to take down the current plasterboard and put up 30-40mm insulated plasterboard.
Might even put some between the joists as well.
