Deleted User 298457
Deleted User 298457
How? The button on the window switches was illuminated but door still opened?Always! Window locks too.
Door locks are usually a switch you need to flip or rotate with the key in the side of the rear door.How? The button on the window switches was illuminated but door still opened?
Found it! Two issues killed with the same stone lol..thought interior door handle on right hand side was broken but it was child lock on, then enabled child lock on other side. Thanks!Door locks are usually a switch you need to flip or rotate with the key in the side of the rear door.
Surprised its such a considerable jump.Good garage that, ive banded their name around a few times on here - wish i had similar for BMW and Porsche. Makes running any Mercedes a non issue.
My E63S turns 3 years old on the 26th, so put it through its first MOT which it sailed through no problems. Got a warranty renewal notice, so logged in expecting a reasonable price as the E43 was very reasonable (about £460 for a year) and was quoted £1360 for a yearSurprised its such a considerable jump.
If it’s anything like my AMG before I traded it in parts had become more difficult and expensive to source from Germany.
Can't see them not doing a live reveal like they did for the SL for a car as important as the C63 to the AMG brand.
I thought the new C Class would only have 4 cylinder engines including in the AMG models? If you're hoping for a V8 then you may be disappointed.
How much is an MB warranty? If you are planning on servicing it at MB, then you might as well get the warranty. If you're going to use a good indy, I'd take a punt without a warranty.The warranty on my E is up at the end of the year.
What are peoples thoughts on swapping the car, buying the warranty, or just YOLO'ing without warranty?
I guess big bills could come up - it has air ride. It is relatively low mileage though (almost 13895 miles) and typically only enjoys longer trips on v power.
I have considered an X3M but I imagine they'll be on the slightly older side of things; and the Merc SUV type cars are mostly out of budget.
Hmm
