NVIDIA GeForce RTX 3090 Ti, the flagship reinvented
NVIDIA to Bundle Power Adapter with GeForce RTX 3090 Ti
https://www.techpowerup.com/293248/nvidia-to-bundle-power-adapter-with-geforce-rtx-3090-ti
For those looking to invest in a GeForce RTX 3090 Ti card, but being unable to acquire a new power supplies with a 12VHPWR connector, there's good news today, as NVIDIA is said to be bundling a power adapter with the cards. The adapter does have its own requirements though, as it's a three to one type of adapter, which means your power supply still needs to have at least three 8-pin PCIe type power connectors. The adapter is said to be able to deliver 450 Watts of power to the upcoming graphics card, which is in line with the various leaks and rumours about the GeForce RTX 3090 Ti.
It's worth keeping in mind that these types of mechanical adapters won't allow the graphics card to communicate with the PSU, something that will be reserved for ATX 3.0 power supplies it seems. It'll also lead to some extra cable tangle near the graphics card, as the design of the pictured connector doesn't exactly look slick or space saving. Hopefully some power supply manufacturers will come up with a neater solution, until the transition to ATX 3.0 PSUs take place.
https://videocardz.com/newz/geforce...th-3x8-pin-to-pcie-gen5-16-pin-power-adapters
PCIe Gen5 cable adapter to feed 450W of power
The upcoming flagship RTX 3090 Ti graphics card will require special power cable adapters.
According to the leaks, the NVIDIA GeForce RTX 3090 Ti has a TDP of 450W. With such a high power input, even two 8-pin PCIe power are not sufficient, such configuration can only sustain 300W of power.
This is a major difference between the RTX 3090 and RTX 3090 Ti cards. The Founders Edition of the former flagship SKU released in 2020 features a 12-pin connector (basically the same cable but without the ‘sense’ pins). It shipped with dual 8-pin to 12-pin power adapter. This is obviously enough for the 350W TDP because the card still has access to 75W of power through the PCIe interface.
The RTX 3090 Ti with 100W higher TDP will need three 8-pin power cables or a native implementation of the 12VHPWR (12+4 or 16-pin) PCIe Gen5. However, the power supplies with the native cable will not be available in time for RTX 3090 Ti, which launches on March 29th. For this reason, the adapter is required.
The adapter will provide 450W of power alone and a total of 525W with the PCIe interface. One should expect a number of custom RTX 3090 TI designs to reach 500W of maximum TDP.
The RTX 3090 Ti features a GA102-350 GPU with all 10752 CUDA cores enabled. This is NVIDIA’s first RTX model with 21 Gbps GDDR6X memory and new power connector. The RTX 3090 Ti should be the last flagship Ampere SKUs to launch before NVIDIA unleashes its Ada GPUs later this year.
Ohh yes... while reading this play this tune... :-
:cry:
RTX 40 series are going to be comical and I bet you, you will see 4090 and 4090ti versions with 2 x 16 pin connectors and even maybe an extreme 4080 version. It has got past a joke now with power use and this is basically warming up AIBs to make the 40 series and how to manage the power, with all this power these cards are going to end up with double the power phases adding to an already expensive card so expect the cost of the power design to add to the costs next round too, we have now seen what Hopper is and at 700w design but it clearly can do another 200-300w more as did with the Ampere A100 that was 400w but also came in 600w versions.
Welcome to brute force computing with silly power use from now on.:(
Back to the good old days...
Devil 13 Radeon R9 390 X2 16384MB GDDR5 PCI-Express Graphics Card (AXR9 390 II 16GBD5)
Product information:
PowerColor Devil 13 Dual Core R9 390 is built with carefully-designed Platinum Power Kit and ultra-efficient thermal design. It consists of massive 15-phase power delivery, PowerIRstage, Super Cap and Ferrite Core Choke that provides the stability and reliability for such high-end graphics solution. To support maximum performance and to qualify for the Devil 13 cooling system, 3 Double Blades Fans are attached on top of the enormous surface of aluminum fins heatsink connected with total of 10 pieces of heat pipes and 2 pieces of large die-cast panels. This superb cooling solution achieves a perfect balance between thermal solution and noise reduction. The PowerColor Devil 13 Dual Core R9 390 has the LED backlighting that glows a bright red color, pulsating slowly on the Devil 13 logo.
The Dual BIOS button design allows gamers to pursuit extreme performance in the easiest way to control. Four units of 8 pin PCI-E power connector draws more power offering constant and stable power input. What's more, to honor Devil 13 users, we have included the top-notch gaming mouse, the Razer Ouroboros, as a free gift inside the box. Why? Simply because we strongly believe our Devil 13 users deserves to have the best of the best.
The PowerColor Devil 13 Dual Core R9 390 graphics card supports for AMD LiquidVR™, GCN Architecture, Mantle, Exploit DirectX© 12, AMD CorssFire™, Virtual Super Resolution, HD3D technology, Frame Rate Target Control, and AMD FreeSync™ technologies. Once more, the Devil 13 has risen from Hell and will once again dominate the extreme gaming world with ease.
Specification:-
- GPU: Grenada Pro x2
- Stream Processors: 5120
- Core Speed: 1000MHz
- Memory Speed: 5400Mhz
- Memory interface: 512-Bit
- Memory capacity: 16384MB GDDR5
- PCI-Express X16 lane required
- 1000W Gold or greater PSU required
- Power Connectors: 4x 8-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Includes Razer Ouroboros Gaming Mouse
- Warranty: 2yr
Can't wait to see 4 x 16pin in the future on GPU cards :cry:, they said 4 x 8pin would never happen too...:rolleyes:
The RTX 5090 will need a 5kw psu plugged in to an electric car charging point I heard.
Rolls Royce has been contracted to produce domestic small modular nuclear reactors to power the RTX 6090.
Why does NVIDIA feel desperate lately? It feels like for a while now what else is setting in the warehouse that we can flog...
Way too many SKUs and releases they been learning from mobile phone companies. Its as if they feel they cant go more than 6 months without releasing a new product.
3090Ti is for those who really did purchase the 3090 for more than just BS'ing. 10% more performance is another half day of production per working week over the 3090.
@Grim5 you need upgrade that relic. On the plus side you will have a start button on the left and the middle. One of the benefits of OLED :D
NVIDIA GeForce RTX 3090 Ti is just 5% to 10% faster than RTX 3090
According to various reports, the RTX 3090 Ti is not really a big upgrade over the original model.
https://videocardz.com/newz/nvidia-geforce-rtx-3090-ti-is-just-5-to-10-faster-than-rtx-3090
So as expected then. I mean looking at the specs from the first page of this thread the 3090 Ti looks like the full GA102 die which is only a couple more GPU clusters more then the 3090, I'm guessing the rest of the TDP is being driven by higher clocks on the memory and core.
NVIDIA GeForce RTX 3090 Ti costs 1,999 USD, 3DMark Performance leaked
https://videocardz.com/newz/nvidia-geforce-rtx-3090-ti-costs-1999-usd-3dmark-performance-leaked
NVIDIA GeForce RTX 3090 Ti launches at 1999 USD
The MSRP of the new flagship RTX 30 GPU has been confirmed to be 500 USD over RTX 3090.
The RTX 3090 Ti will launch at 1999 USD, which is the suggested retail price for the Founder’s Edition. Most custom models are more than likely to cost more. From what we have been told, some big US retailers already have thousands of the cards in stock and more coming, which given how niche such a model SKU is, it shouldn’t sell out quickly.
The detailed performance figures will be presented later today by independent reviewers. Those tests will cover the custom designs from NVIDIA board partners. The reviewers that we talked to claim that NVIDIA did not sample Founders Edition. In any case, in raw 3Dmark benchmark, the card appears to be 7% faster on average. This is a comparison based on custom RTX 3090 Ti and RTX 3090 cards from the same company and from the same series.
What is kind of interesting is that there are a number of custom designs based on a V-shaped PCB design, possibly the same or slightly modified board as NVIDIA’s own Founders Edition. This should apply to cards such as Gigabyte’s AORUS Xtreme and GAMING OC. The AORUS Xtreme Waterforce is yet another design with 360mm radiator. Such designs are rare and have only been used by very expensive SKUs such as Sapphire RX 6900XT Toxic Extreme or EVGA RTX 3090 Kingpin Hybrid.
