If you want to discuss goats can you do it in a separate thread. It has nothing to do with this one.
This please, the same subject is coming up in every race thread and it’s tiresome.
Has the red flag tyre change rule been changed or is it the same as last year?
GOAT - Apart from the fact i stated he’s been gifted 4 of his 7 WC titles ! Other motor sports - Rossi 89 wins from 55 poles 9 WC over three different classes epic legend . Now you might say what’s the difference , similar amount of champions ect under different classes . The difference is a larger part of Rossi’s competitors all had GP winning bikes , for 7 years Mercedes’ have had it all there own way and had no one come close , barring Ferrari for a few races.
If you look at my previous posts you will see my logic, It killed the sport from a fans point of view for 4 years yet the larger part of UK motor sport fans think he’s god. I can’t see the logic in it at all. A lot of races I literally turned over the channel.
Like I said it finally changed last year and this year for the better of the fans and to be blunt I can’t see Lewis winning another WC for the rest of his career.
Now if he took the red car in 2025 and won a race I’d then put him into Epic territory. Not going to happen .
Anyhow Popcorn ready for later, go on the Checo! Go on the George .
Same as last, AFAIK. What did you think has changed?
After this incident there was a lot of fuss:
Aye, Teds notebooks on race weekends are sometimes better than the race.Missing Martin and Ted this weekend.
blah GOAT blah
Not seen anything reported yet but with the warm up show just starting, I’m sure we’ll know soon.Any word yet on if Lewis is starting from the pit lane?
No need to change parts. They only need to break a seal to trigger the penalty.
Think back to when Ferrari opened Massa’s gearbox (broke the seal) to get him a grid drop behind Alonso.
If Merc want to start from the pit lane and make setup changes they won’t physically need to replace parts.
Cant believe they haven't changed anything. Stick Russell's setup on and see what happens
You can do drastic setup changes, without physically changing any actual parts.
Undoubtedly they have gone back to a previous setup.
Unlikely to be Russell's though, as their driving styles are quite different, so what works for one, doesn't necessarily work for the other.
40) PRE-SPRINT AND PRE-RACE PARC FERMÉ
40.1 Each Competitor must provide the Technical Delegate with a suspension set-up sheet for both of their cars before each of them leaves the pit lane for the first time during the qualifying practice session.
40.2 Each car will be deemed to be in parc fermé from the time at which it leaves the pit lane for the first time during the qualifying practice session until the start of the race. Any car which fails to leave the pit lane during the qualifying practice session will be deemed to be in parc fermé at the end of Q1.
Between these times, other than when cars are sealed overnight in accordance with Article 40.634.5, the following work may be carried out:
a) Engines may be started.
b) Fuel may be added or removed and a fuel breather fitted.
c) Wheels, wheel fasteners and tyres may be removed, changed or rebalanced and tyre pressures adjusted.
d) Spark plugs may be removed in order to carry out an internal engine inspection and cylinder compression checks.
e) Permitted breather, heating or cooling devices may be fitted.
f) A jump battery may be connected and on-board electrical units may be freely accessed via a physical connection to the car.
g) Charging and / or discharging of the ERS energy storage devices.
h) The brake system may be bled.
i) Engine oil may be drained.
j) Compressed gases may be drained or added.
k) Fluids may be drained and/or replenished, however, fluids used for replenishment must conform to the same specification as the original fluid.
l) The aerodynamic set up of the front wing may be adjusted using the existing parts. No parts may be added, removed or replaced.
m) If the FIA Technical Delegate is satisfied that changes in climatic conditions necessitate alterations to the specification of a car, changes may be made to the brake ducts, as described in Article 3.13 of the Technical Regulations, and to the engine and/or gearbox cooling bodywork that lies within the RV-BODY-REAR and/or RV-RBW-EC reference volumes, as defined in Appendix 1 of the Technical Regulations. These changes may be made at any time after all Competitors have been sent the message “CHANGE IN CLIMATIC CONDITIONS” using the official messaging system. From this point onwards the choice of brake ducts and engine and/or gearbox cooling bodywork is free and pitot tubes may be covered or uncovered, subject always to compliance with the relevant Technical Regulations.
n) Bodywork (excluding radiators) may be removed and/or cleaned.
o) Cosmetic changes may be made to the bodywork and tape may be added.
p) Any part of the car may be cleaned.
q) On board cameras, marshalling system components, timing transponders and any associated equipment may be removed, refitted or checked.
r) Any work required by the Technical Delegate.
s) Changes to improve the driver’s comfort. In this context anything other than the adjustment of mirrors, seat belts and pedals may only be carried out with the specific permission of the Technical Delegate.
i) Should ambient temperature change significantly, Competitors will be requested to change the head padding required by Article 12.6.1-6 of the Technical Regulations using the official messaging system.
ii) The addition or removal of padding (or similar material) is also permitted but may only be carried out under supervision and, if required by the Technical Delegate, must be removed before the post-race weighing procedure.
t) Drinking fluid for the driver may be added at any time, however, the capacity of the container for any such fluid must not exceed 1.5 litres.
u) Repair of genuine accident damage.
v) Any parts which are removed from the car in order to carry out any work specifically permitted above, or any parts removed to carry out essential safety checks, must remain close to it and, at all times, be visible to the scrutineer assigned to the relevant car.
i) Furthermore, any parts removed from the car in order to carry out any such work must be refitted before the car leaves the pit lane.
40.3 Any work not listed in Article 40.2 may only be undertaken with the approval of the Technical Delegate following a written request from the Competitor concerned. It must be clear that any replacement part a Competitor wishes to fit is the same in design and similar in mass, inertia and function to the original. Exceptionally, at an Event where a sprint session is scheduled, replacement parts that are different in design will be permitted provided that the part is of a specification that has been used previously in a qualifying practice session or a race. In such cases, the Competitor should inform the FIA prior to the start of the sprint session of any part where this may be necessary. Any parts removed will be retained by the FIA.
If a Competitor is granted permission to change a survival cell, any of the additional components detailed in Article 27.2 may also be changed provided that the spare survival cell was already fitted with these additional components at the time of the request.
If a Competitor wishes to change a part during the qualifying practice session, on the grid before the start of the sprint session and between reconnaissance laps and/or on the grid before the start of the race, this may be done without first seeking the permission of the Technical Delegate, provided it is reasonable for the relevant Competitor to believe permission would be given if there was time to ask and the broken or damaged part remains in full view of the scrutineer assigned to the car at all times.
