Going to call them liars then, they just don't want people on it.I asked British Gas to do this, they told me they don't support it![]()
Working out my monthly;
That averages out at £220.07 a month for 12 months on variable. My fixed offer is £238 a month so better off even with the October rate increase. To note with that my usage is actually pretty similar between summer and winter months but if you are at 10% higher usage then it would actually work best even on the stupidly high fixed price probably.
- From April till September based on past 12 month usage then I will be at £192.20 a month for Gas and Electric
- From October to March based on past 12 months I will then be at £247.94 a month for Gas and Electric which is assuming the 29% October increase that has been touted at moment.
Nice to see the pricks are fiddling their meter readings. **** the rest of you, I only care about myself eh. Thank christ the whole world isn't like these people.
You mean better off on the variable I assume?
Wouldn't be the first time they've lied to meGoing to call them liars then, they just don't want people on it.
Most bills are based on estimated readings (supplier based) no one is sending out monthly people for reading meters anymore so how accurate are the actual readings. Never submitted mine until this year (EDF)
No, it's quite easy. Hagar was talking about the Fuel Duty cut not being passed on and companies pocketing the difference, you were the one who then equated that to the same scenario as an Income Tax cut and companies pocketing the difference, when they are not comparable situations at all as it doesn't work the same wiith Income Tax as it does with Fuel Duty, as I've explained.
EmbarrassingNice to see the are fiddling their meter readings. **** the rest of you, I only care about myself eh. Thank christ the whole world isn't like these people.
Is there a decent web page that shows how much electrical devices consume eg TVs & PCs in standby?
I've just read that a TV can cost up to £3 a year in standby mode which doesn't sound a lot.
Okay for the big energy companies to fiddle the direct debits and make people over pay though right?Nice to see the pricks are fiddling their meter readings. **** the rest of you, I only care about myself eh. Thank christ the whole world isn't like these people.
we're looking at Solar on the roof with a battery.
Unfortunately, its expensive.
Around 12k to get enough panels with a 5Kwh battery.
It may only charge 4Kwh during the sunny periods of the day (on avg)...
We use around 7-12Kwh per day based on our current usage.
Nor is it practical... would take over 12 years to pay back its cost in the savings.
Sounds like you're jelly you didn't think of saving a few £££Nice to see the pricks are fiddling their meter readings. **** the rest of you, I only care about myself eh. Thank christ the whole world isn't like these people.
I recently used a watt meter to measure
values the government analysis used - I linked earlier - personally haven't metered the upright freezer and fridge-freezer yet,Is there a decent web page that shows how much electrical devices consume eg TVs & PCs in standby?
will probably be an update in January if the 3 month 'out for comment' gets pushed through, DE emergency planning for cut-off gas flow are obviously ominous.Working out my monthly;
