Thanks dowieAh, I think that was a missile attack by Ukraine.
Yeah, literally blows the tail off. Those things are so rapid that it looks like a rail gun hit, one second it's flying normally and then a millisecond later BOOM!
Kind of crazy, you dont see any indication at all until the chopper just snaps in half.
For all the **** ups our government has done recently, its hard to disagree with the effectiveness of the UK supplied weapons, and that we were first to be providing them and in such quantity.
This looks like great/monumental news but sadly it's just hot air.
It's good that they are doing more to try and help but you have to question how much use this will actually be. As pretty much every country who use ex-USSR tanks use Russian built T-72s, whereas Ukraine use the Ukrainian built T-64 and T-80/84 tanks. This means the tanks likely to be sent to Ukraine will be T-72s and probably older ones (in some cases they may actually be ones Ukraine sold off in the 90s), which means none of the Ukrainian tankers under the age of 40 will have been trained on them and they will be in an equal/worse state of modernization/survivability to the junk Russia failed to invade in.
The only states with decent tanks of the types Ukraine use, and enough of them to make sending some worthwhile, are China and Pakistan, neither of which are likely to want to **** off Russia.
I assume they would track the hottest part of the exhaust which is probably around there.
AFAIK its not infra-red tracking its laser guided. Which is also why its so effective against countermeasures.
It looks like the Russians are in full retreat in the north of the country. Ukraine is recapturing territory at such a rate they can't update the maps quick enough.
Maybe but you have to wonder what state their in after 5 weeks of fighting. It also allows eliminates the threat of Russian occupation in all the other Ukrainian towns around those cities in the north.Sadly all those forces will heading to reinforce the East and push through there.
Is it really all that surprising given the recent bad blood we have with Russia over the Polonium and Novichok poisonings in the last decade ? This is the perfect way for us to get back at them without actually risking an all out conflict
@0007, I appreciate the updates, keep them coming.
— Bloomberg (CET Time)*Ukraine Says Russia Building Up Troop Levels in Moldova
Quite. Credit where it is due; the British government has done a great job in backing Ukraine's defence.
Given how soaked the Tories are in Russian donations, I find it really quite surprising how good they've been on this. Also, Russia has been up to plenty of shady business across the West, so I'm not sure that the UK really has more reason to seek revenge against Russia.
Indeed. IR flares have made heat-seaking SAM and A2A missile systems mostly ineffective.
