Please spec me a reliable fast external HDD
7 Sep 2009
London
Hi, I've started doing a lot of video and my space is getting murdered.
I've looked at various HDDs on amazon but hoping for some experience. Reviews vary widely and expect some fake ones.
Hoping to edit video off it, so needs to be fast.
Thanks :D
Editing video off an external HDD, i honestly would not bother, far to slow imo. However more information is needed, computer spec, video format, and budget.
For now i will just say you can get a good external 1tb SSD for ~£100.
Though i expect you could get a budget SSD and an enclosure for less than £100, moreso at 500gb.
I recently picked up WD sn550 2tb for £145 for the same reason as you, my boot drive and games drive have got murdered for space as i've been filming more than i can keep up with atm.
Tbh it's more to manage the space. I took some clips the other night and it took up 64gb.
So I'm thinking 8tb +. I can then move things back and forth when I edit off the NMVE's.
I'm editing 4k vids on a 5800x, 970 nvme x2 , 3080ti, 32gb
Maybe a dual bay raid 1 setup externally then? I'd get a mod to move this thread over to the storage forum, might get some better responses than mine :P
I will say it depends on your end game if you've thought about it? How long will you keep clips before edit/delete/finalise and if they want being backed up?
For me 2tb SSD is enough to keep me going until i sort it all out, delete what i don't want, edit, and output to final video- it's just quick. However i do have a same day backup using a 1tb external SSD to be safe after filming, it transfers fairly fast but does hang a tiny bit as the memory chokes with the big files. The whole lot gets then gets moved and backed up on internal HDD and a few portable HDDs -for budget reasons.
Ah didn't realise there was a storage forum.
I tend to hold onto various clips. They are quite hard go get. I'll browse that sub forum to get some ideas.
