It’s impossible to say without more information. At the moment its neither moral or immoral based on the information we have. That type of increase can be perfectly justified meaning it’s not immoral. If that cost is justified I wouldn't call it moral but at the same time its not immoral, it can be neither.What do you think @Pottsey : moral or immoral?
its like a 45% increase totally fine as long as I'm not the one rentingIt’s impossible to say without more information. At the moment its neither moral or immoral based on the information we have. That type of increase can be perfectly justified meaning it’s not immoral. If that cost is justified I wouldn't call it moral but at the same time its not immoral, it can be neither.
Really?
I bought a property outright and then let it out, does that make me greedy and a bad person?
Under what real world circumstances would a 33% rent increase for an active tenant be morally justifiable?It’s impossible to say without more information. At the moment its neither moral or immoral based on the information we have. That type of increase can be perfectly justified meaning it’s not immoral. If that cost is justified I wouldn't call it moral but at the same time its not immoral, it can be neither.
Read it againIt's not an active tennant? He said it's for new tennants.
A lot of landlords don't increase the rent year on year. For all we know that 33% could be covering a 5 year, 10 year or even 15+ year timeframe with no increases. Its common practice to either wait till the current tenets leave then adjust the prices or wait as long as you can before you have no choice then increase the rent in one big go. Landlords are not all immoral like you say and some of them try to protect and avoid passing on costs to the tenets as long as possible. But there gets to a point where the price just has to go up. Plus there is supply and demand if the area is in heavy demand for renting then it might be justified to up the price.Under what real world circumstances would a 33% rent increase for an active tenant be morally justifiable?
I'm starting to think you'll defend anything landlord related and actually have no moral compass on the issue at all.
I have logically explained why landlording is inherently immoral , using real economics, and you are defending a 33% rent increase.Its more likely the problem is not me having no moral compass as that is not true, but you have an overly negative viewpoint of the world and see the worst in everything at least that is the impression I am getting of you
Fair enough, I have no argument with that.Been through all this earlier.
If you own the property outright then you can make a decent income while charging a fair rent price, the issue we have is too many landlords are trying to make as much money as possible from one property which has to cover the repayments on the mortgage, all costs associated with the rental and a monthly profit on top. That puts the monthly rent much much higher than an equivalent mortgage and is not sustainable.
If despite your lower costs due to owning the property outright you continue to push up the rent you charge then yes that does make you greedy.
No you have not logically explained why landlording is inherently immoral. Your explanation I found flawed and incorrect so I don't accept is as a valid reason for saying land lording is inherently immoral, using real economics. I am defending the 33% increase as it was an increase to cover multiple years at a time in a location that has got more desirable. It was not 33% a year. Its 33% over multiple years. Also it was not for active tenets and in this case active tenets never get an increase even over multiple years proving the landlord is not immoral like you say they are. If they where immoral they would increase every year.I have logically explained why landlording is inherently immoral , using real economics, and you are defending a 33% rent increase.
Come on my friend.
EDIT: Just seen the post before mine. So it turns out the tenants never had any increase while they lived there and this is an increase to cover multiple years in what is a desirable location. It was also not an increase for the active tenants but for new tenants.
Note that you still defended it when you thought it was an active tenant increase.No you have not logically explained why landlording is inherently immoral. Your explanation I found flawed and incorrect so I don't accept is as a valid reason for saying land lording is inherently immoral, using real economics. I am defending the 33% increase as it was an increase to cover multiple years at a time in a location that has got more desirable. It was not 33% a year. Its 33% over multiple years. Also it was not for active tenets and in this case active tenets never get an increase even over multiple years proving the landlord is not immoral like you say they are. If they where immoral they would increase every year.
especially with my very strict criteria.
Did you miss where I said "For all we know that 33% could be covering a 5 year, 10 year or even 15+ year timeframe with no increases." "Its common practice to either wait till the current tenets leave then adjust the prices or wait as long as you can before you have no choice then increase the rent in one big go."Note that you still defended it when you thought it was an active tenant increase.
I don't think a single 33% increase would ever be OK for an incumbent tenant. Unless pre agreed as part of major upgrade work.Did you miss where I said "For all we know that 33% could be covering a 5 year, 10 year or even 15+ year timeframe with no increases." "Its common practice to either wait till the current tenets leave then adjust the prices or wait as long as you can before you have no choice then increase the rent in one big go."
see what I mean you seem to jump to the most negative version of events. The problem here isn't me, its your negative viewpoint of life. As it turned out I was right the increase was covering multiple years and your negative viewpoint was wrong.
I'm not sure what you are thinking, but you're probably rightI think I know the plot for this one...![]()
That would be rather large for a incumbent tenet yes I agree with that. The rest is where we disagree to me a 33% increase between tenants its perfectly acceptable as long as it covers enough years to justify the increase since the last increase and supply and demand match's. If a landlord hasn't increase for many years and does a 33% increase between tenets to cover a long time frame and is still below the area average rent you cannot argue that landlord is being immoral as they are not.I don't think a single 33% increase would ever be OK for an incumbent tenant. Unless pre agreed as part of major upgrade work.
And, frankly, I don't think it's OK to defend a 33% increase between tenants either. There's no way to argue that's anything but a societal Bad. And we shouldn't defend structures that create societal Bads.
