- 21 Jul 2005
- Officially least sunny location -Ronskistats
Steve added Ghost Recon as heavy on the vram on that vid too!![]()
He mentioned
+1 on the 8gb@1080p.
Not be long for the next 'wahaaaay it uses less than 10gb' vid, bricking it we are!![]()
You guys do realise that the debate in the original FC 6 thread was originally about the 3080 and 10 GB vram (something which hub did not report issues in their recent 3080 vs 6800xt video), talk about moving goal posts againJust concretes my points even more
Seen the gif![]()
Who buys a 3060 Ti for 4K? A 2080 is not enough for 4K and a 3060 Ti is not much better than it... I am lost at this point, I think all people in here care about is Far Cry 6 and have ego problems, I must be right and that is the end sort of mentality.Yep. Here's what Steve had to say:
3060 Ti to the 3080 are the low and high end of 1440P, the mid range is the 3070 and Ti model.
HUB does benchmarks to prove performance in an apples to apples way, but people don't use these cards in an apples to apples way, anyone with critical thinking ability will see the 3060-3080 cards suck at 4K and would likely be buying 3080 Ti or 3090 & Ti and if the budget cannot fill the experience, sticking to a lower resolution, but then we are not all made with brains that function intelligently.
Strictly speaking about GPU performance here, not Vram.
Its true, the sites tend to test all cards up to 4k. I have mentioned it before then you get smart comments like what is 4k gaming? Yet its plastered all over these reviews and even printed on the boxes of the cards themselves.
That doesnt make any sense. The 3080 is most definitely marketed as a 4k card.
Your response is a projection of your own feelings mate. I am sat at work waiting to start my shift drinking a Pespi.Think about what you are posting before getting all triggered.
Stifles intelligence.
To me the only 4K cards are the 3080 Ti and 3090 (Ti) along side the AMD equivalents.
