The Radeon RX 6900/6950 XT Owners Thread.
If you can point me towards some (reflections) near the start of the game, I'll take some screenshots and or do another video.
Keep it near the start though, don't mind playing for a bit longer near where my last video ended.
Yes it does. Actually RSR should work with Doom, so I'll grab some screenshots with that enabled also.
CPU looks normal to me.
From 12 minutes onwards in my video, you get some more mirror/metal/glass surfaces.
There are a couple of maps/areas further on in the game which are very orientated around reflections with all the metal but I think they might be a bit further in the game e.g.
Okay I'll have another look and put together some more screenshots and or a video.
Howdy all,
New to the forum but have been reading quite a lot of the comments over the last few Months. This Forum has helped me decide on going Red (Yellow) Team in regards to my GPU. However, I was was wondering if anyone else had encountered a max fan speed on their 6900xt Toxic Extreme GPU, basically, no matter how hard I push it the fans never go above 950rpm - the only time I can max them out is when I run the Fan Check in the Trixx Software?
Also, on the Toxic, I can't seem to hit max Clock speed - even when running Furmark or Heaven.....
....Any hints or tips would be most welcome :confused:
Hey Ash, have you checked that your bios switch is set to Performance mode? It may be set to Quiet hence the fan speed. Have you altered your Power Limit settings or left it alone?
I have the same card and it's stunning, fast AF :cool:
JediJ, I'm on performance Bios with Toxic Boost, maybe i'm not getting it hot enough?
Not adjusted any power settings, its fast but I'd like to know everything is working correctly!
Never goes above 70 degrees (according to Icue) never above 55 degrees according to Trixx?
I've had it up to 2700 on the GPU Clock.
Probably need to find something that really pushes it, Warhammer Total War 3, maxed everything, getting 133.5 fps!
It's a beast for sure, but I would like to push it to its limit just to see and hear the fans ramp up!
I don't suppose you know if there is anyway to adjust the fan curves?
Edit, finally the fans have ramped up, at 65 degrees (Trixx) and 80 degrees (Icue) they go up to 1500rpm. Using PassMark Performance Benchmark.
In the AMD software - performance - tuning - choose manual tuning for gpu and fan tuning enabled, advanced control. Then you can change the fan speeds manually.
I tried installing the AMD 6900xt software, but it won't install and the card runs off Trixx....unless someone else knows different?
So I'm not the only one? Adrenaline says an error occurred at the end of install, but it does actually install. Weird.
Hello guys im new here. Got the toxic Extreme. Got it to 256xx graphic score and avg boost timespy 2820 coreclock with 2150 fast memory. Game clocks at 2930mhz stable. Max temps gaming 76 junction and timespy peaks junction at 83c.
Saw the thread about what it Can do and though i would answer it
Nice!
Nice scores, how did you get those clocks - they are a bit above Toxic Boost?
