- 2 Feb 2008
- Rainham - Kent
Nice one thanks for that![]()
There's an offer running at the moment, looks like it'll be running for awhile, hopefully this helps @mr griffin
Im really not sure why they get so much negative press really they have been great for me?
No issues here either, seems quite region specific.Been with virgin for 3 years now and totally happy... now on the 1gb and its fast, low latency and no issues at all. Billing correct every month and customer service is fine.
Also the amount of jitter on VM is considerably higher than on most other FTTP connections, also their network tends to have periods where the pings spike & you see random packet loss.Define 'low latency'? Are your pings single digits to the UK and most of mainland Europe?
I thought the purpose of the thread was to suss out which one is better over the other objectively, something being 'sufficient' enough for 'most' is a completely different point to the one I'm making.This is all well and good but in actual usage it's fine for lots of people. Fairly heavy usage household with next to no issues. Gaming, streaming, downloading, browsing, work video calls, whatever. Minimal issues, on the whole.
Not to mention the amount of issues you hear people on VM have because their area/location has capacity issues or is under some sort of maintenance.
Yeah literally I'd take a 100/100 1ms connection over a 940/940 flaky connection w/ some packet loss if it meant things were stable.. You don't even notice unless you've had a comparison, then suddenly you'd trade half your speed just to get low latency and no bloat!
I'm genuinely curious to see the difference, so post back here after you've aggregated some stats over a period.Smokeping is now running btw.
I feel most people just look at the Mbps, rather than speed as a whole - latency/packetloss/downtime which are some of the more important factors.
I'm using a step of 60 (every 60 seconds), and pings of 10. Rather than the default of 300 (every 300 seconds) & step of 20 so I have a lot more data, (if you do it, delete RRD graphs after you've made changes or you'll get an error.)
I suggest changing the stuff at the bottom aswell if you want to maintain/keep old data, otherwise it gets removed after a few months to make room in the DB - this was very frustrating to me as it took me months to realize this
An ADSL 20Mbps connection is great for some people aswell.There is no debate, fibre is better. Just that for a lot of people VM is great.![]()
Same with 3G, it's great for some people, some people don't even need 4G/5G connectivity.
It is all dependent on use case, but when a thread is made to compare the two, I'd expect the differences to be made clear and the advantages.
There's always an argument to say something is excessive or unnecessary with everything.
Thread is already answered but people have now started wanging on about buffer bloat and all sorts of guff that 99% of users wont even have the hardware to put into affect anyway.![]()
OP said:Also while I'm here is FTTP superior for lower latency in gaming than Virgin media?
