Caporegime
- 9 Nov 2009
- Planet Earth
No problem!
If i buy new Zen 3 cpu, i would get 5800x3d, performance gain in minimum framerates are excellent, and 8 core Zen 3 is enough for many production workloads.
Mine arrived today, won’t be able to install until later this week. Replacing a 3700x, it’s the increase in the lows that I am most interested in as I game at 4K on a 3080.
Can you post some benches when you get up and running please because I suspect you won't notice much in any difference over a 3700x at 4k but I would be very interested to see a "real users" analysis
Can confirm i noticed no change in Valhalla at 4K max settings, did not test lower resolution/settings yet but it looks like the cache does very little there.Tried running benchmarks on three games. My setup is a 3090 strix oc, 32gb 3600 cl17 and a AMD 3900x stepping up to the 58003XD. AC and Watch dogs were at 1440p and ff15 at 2180p with all graphics options maxed.
On AC Valhalla my old frame rate was an average of 88 fps and this went down to 87 fps on the 58003XD. Think this was a GPU limited game so not much change. FF15 had no change either but Watch Dogs Legion went from an average of 71 fps to 79 fps which is a very good improvement.
I have a 5800x3d
B550M TUF PLUS - latest bios
32GB (4x8gb) 3200 cl14 Team Dark Pro DDR4
I can achieve the 4.55 by Going into the Advanced Section of bios enabling cppc preffered cores,
and in AMD CBS and I found PBO. I just enabled it and now i get the 4.55 on 2-3 cores.
Also, there is the Manual option which allows you to add ppt edc etc
and a Scaler
Why can I see PBO this chip is supposed to not oc
I'll check againAMD asked board vendors to disable it, maybe they didn't ask hard enough, do you have Max CPU Boost Clock Override in that BIOS?
I'll check again
Also, does any know some good 3600/3800 timings for dark pro 3200 cl14
I don't know where it would be in your BIOS, but not there, this is what it looks like in mine, its in the main tweaker menu, AI Tweaker in yours?
I suspect in most cases you are right but I'm betting when that 3080 gets swapped out for a 4080 there will be more benefit. I think it will stay relevant for longer than any other current CPU for gaming.
Looks like World of Warcraft is another game that loves 3DVcache, 40-50 FPS improvement over Ryzen 5000 series.
Blimey that is an improvement. Looks like I made a safe bet on this one, at least for my modest requirements. I'm hoping we can under volt it, more performance with less power and heat is even nicer.Looks like World of Warcraft is another game that loves 3DVcache, 40-50 FPS improvement over Ryzen 5000 series.
