Handy graph above, showing core scaling on a 5950X and power requirements at different clock rates.
We can see that a package power of around 135w on an 8 core CPU should result in clock rates of 4.6ghz.
300 score more than me on one ive set to 4650 all core and 1.21v maxing at 62c5800X tweaked, that's running at about 4.7 to 4.75Ghz all core. ~80c, 110 watts package power.
good volts for those clocks.
So I've picked one up now for my SFF build as the 5900 just couldn't stretch it's legs properly and let off so much heat it was unreal in the Q58.
Tonight I've been messing about and clocked the 5700X @ 1.2V, All Core 4.6Ghz.
R20: 6026
R23: 15385
Temperature wise full load I'm maxing out at around 72C but this case is a bit of a hot box despite a 240 AIO (seem that the top panel just heats up to some crazy level which doesn't help). In game however it is reaching nowhere near that and usually between the high 50's/low 60's. I'll monitor it over the next few days but its seems absolutely solid right now.
Nice, i was thinking about doing an all core overclock but wanted to see how it goes letting AMD do it for me first
Does this drop the core speeds down and do the volts drop down when not running games or anything and what are your idle temps?
I use Windows Power Save when im not doing anything heavy, saves a lot of energy and temps go down into the high 20's.
So it's a weird one with AMD I find, it just pushes too many volts through for me in an SFF build (fluctuates way too much) and I know there's negative offsets on PBO etc I can try but they generally don't see much on an impact in this build.
Sticking to an all core Voltage and clock speed seems to work ok on Ryzen for me. Temps are usually around 40 idle, 45-50 with a bit of light work and only ramping up temp wise during proper activity. It's typically sitting at anywhere between 30-40w unless gaming. When benching and using all cores 100% it's hitting a max 101W.
Thanks for the info on that, are you using speedstep or global c states with this overclock or would that bring instability? If its possible to use these then i might give it a try, i like a very quiet PC when its idling![]()
Literally all I've done is left everything in default bar the memory profile and then 46x ratio and 1.2v.
