I'm thinking that the monolithic chip is probably gonna be pretty decent. Maybe it will be similar to a RX 6900 XT / Navi21 in die size, but built on a new EUV fabrication process.
I suspect that all the rumours about the performance of high end MCM graphics cards will be wrong. That's because even if the early prototypes spec if accurate, it doesn't mean it will actually be a good design that functions to required specifications, and within acceptable power and temperature limits. Some of the rumours are saying more than double the CU count for the top RDNA 3 card (vs the 6900 XT), it's silly. Not to mention, it would likely be very expensive.
