Caporegime
anyone know if VM are planning to increase upload speeds? we can only get VM where we live so at the mercy of them!
My understanding is it is not possible due to tech they use.
UPDATE 6th May 2022 @ 10:04am
After chasing, the operator has provided an updated statement.
A Virgin Media spokesperson said:
“We’ve now determined the root cause of the issue and can confirm that it’s an issue exclusively impacting traffic passing through an interconnect from our network to the ThinkBroadband server site.
General traffic on our network is not impacted and as a result, the TB BQM is not reporting accurate latency data for Virgin Media customers right now. Whilst we’re looking to address this, we recommend that customers use the SamKnows RealSpeed application or Ookla’s Speedtest.net’s ping test if they wish to check their latency or network performance.”
In response, Andrew Ferguson OBE of Thinkbroadband, said: “It is good that Virgin Media has identified the root cause but we are not happy with the spokesperson appearing to suggest that the BQM is not accurate, it most definitely is accurate and was reflecting the state of all the links between the BQM systems and the customers router. Similar with the speed test we have always run that in a state that will highlight speed issues for individuals rather than trying to counter congestion by opting for a closer server or adding more download/upload links to compensate.”
You can if you put it in router mode and buy a better router I think. But yeah, anyone with a 1gig line should get a HUB 5 imo.Anyone know when the hub 5 rolls out? Not long signed up for gig1 and thought it was strange how I could never get over 1gig turns out the hub 4 can’t get over 1gig.
hi, i've got a question
im moving house soon and i currently have g.fast (900m away from the cabinet somehow), but the new house only has fttc, so we are planning to move to virgin.
i have heard a lot about them (bad latency due to intel puma chipset, general internet issues)
have they fixed many of these issues yet?
btw, what is the latency like? i guess ill plan on getting a dedicated router for vm, im currently getting 2ms on speedtest.net though
A decent FTTC line will be a better experience than Virgin Media except for large downloads.hi, i've got a question
Hub 5's are available in weird test/but-not-test stage. They won't give them to you for 1 gig because (as of a few months back) the VM app doesn't work with them, and neither do the boosters/pods that (as a 1 gig user) you're entitled to get for free. They would rather keep you on Hub 4 where they can supply you with the boosters if you want them and where the firmware is a bit more developed and stable.
The only way some people have done it is to be on a lower tier than 1 gig, get the SH5 offer email, accept the offer email, and then upgrade after your SH5 has been installed. That assumes things haven't changed in the last few months and they still have a 1 gig profile for the SH5 and VM will sent it to you on a speed upgrade.
Is it plugged into a router, or directly into a single device? Either way, on a device with connectivity visit here and it'll tell you.hi, I've got my sh4 in modem mode but can't find the ip address to enter into thinkbroadband Broadband Quality Monitor
router, Asus Zen Pro XT12Is it plugged into a router, or directly into a single device? Either way, on a device with connectivity visit here and it'll tell you.
