Caporegime
- 8 Jan 2004
- Rutland
You're probably one of the closest forum members to little old Rutland!Oh! Well... I can monitor-sit for you if you want?![]()
June 9th just changed to shipped here as well. Just got the text message from UPS! Bit of a surprise, not had a single email update from Dell today about the change in status.
They've not charged me yet.Do they charge your card straight away or on dispatch?
About a day or so later.Do they charge your card straight away or on dispatch?
Don’t worry, they willThe email aviur
Pretty sure DP, as HDMI is not ideal. Try a different cable if you have one.Guys. Could I ask which port wire you're using for this monitor?
I've just got mine now and plugged it into the DP and no picture! Having a late breakfast and then going to try HDMI!
Thanks! Shall do now.Pretty sure DP, as HDMI is not ideal. Try a different cable if you have one.
This may sound a bit silly but make sure you really push it in on the side of the monitor. At least the cable I was using (a club 3d one) it felt like it was in but I didn't get any signal. Turns out I just had to really push it in more for it to go in and lock.Guys. Could I ask which port wire you're using for this monitor?
Thank you btw! That worked. This monitor is ridiculously good! The pixel response!Pretty sure DP, as HDMI is not ideal. Try a different cable if you have one.
Is there a general consensus on RGB vs. 422 vs. 444 and 10 bit vs. 8 bit? I'm struggling to find the discussion on it from a few weeks ago.
Ah thank you for this! Maybe I did this with the new wire I tried! But definitely all good now.This may sound a bit silly but make sure you really push it in on the side of the monitor. At least the cable I was using (a club 3d one) it felt like it was in but I didn't get any signal. Turns out I just had to really push it in more for it to go in and lock.
