Hi,Is it the case that 2.4GHz IoT devices would need to support MU-MIMO to benefit from the 4x4 on 2.4GHz by using different streams (if 1x1 clients) rather than all using just the first? If that's the case then do many IoT devices support that in practice?
I've read lots of conflicting info so its hard to be sure!
It‘s the access point that supports MuMiMo, the clients will all be 1x1 so the AP will run at 4 single channels rather than 2 channels on the Pro. In this case it’s the Mu that is important rather than the MiMo (which would help if the IoT devices were 2x2). OFDMA helps on AX but fundamentally you have double the bandwidth on 2.4GHz on the LR vs. the Pro.
