Yeah AMD is supposed to be a better value option. I don't think this pricing is going to be good for their GPU market rep in the long run. They really should stop trying to be Nvidia.6950 XT costs no more to build than a 6900 XT and both are price inflated despite a reduction in the crypto boom, not to mention segmentation restrictions against the 6800 XT. Lost for words really AMD is 'trying their luck at pricing' again and yes its no worse than Nvidia but that hardly makes it ok.
Dude, you're so out of touch it's untrue.Yeah AMD is supposed to be a better value option. I don't think this pricing is going to be good for their GPU market rep in the long run. They really should stop trying to be Nvidia.
Useless reply is uselessDude, you're so out of touch it's untrue.
You are right. 51.4 vs 62.19mm. 13w higher power draw, and amongst the marketing speak and addition of buzzwords that I know the 6700 nitro+ has, but arent mentioned, possibly these additional features:Might just be me but the cooler on the 6750 Nitro looks thicker than the 6700 in photos
P.S. Might wanna put something more approximate in your location in your forum account![]()
Which is why they're struggling to sell GPUs compared to Nvidia.Amd haven't been the value option in quite some time, their cards are priced around the same as nvidia cards.
3090ti costs no more to build than a 3090 and both are price inflated despite a reduction in the crypto boom, not to mention segmentation restrictions against the 3080ti. Lost for words really NVidia is 'trying their luck at pricing' again and yes its no worse than AMD but that hardly makes it ok.
Yeah although it seems drivers are a lot better this generation. Understandable that people will be wary after previous generations driver issues. Takes a while to come back from something like that.Among other reasons, the usual driver spiel puts people off buying amd cards, and lower ray tracing performance can also be a factor.
I had the worst drivers during my 980 ownership and gave up with them cause of that as years of issues. Switched to a 5700xt and no issues then for myself (I know others did) and this 6900xt has been solid since release day. All swings and roundabouts.Yeah although it seems drivers are a lot better this generation. Understandable that people will be wary after previous generations driver issues. Takes a while to come back from something like that.
True but rightly or wrongly, AMD has a worse reputation for driver problems. It's good that they're turning this around though.I had the worst drivers during my 980 ownership and gave up with them cause of that as years of issues. Switched to a 5700xt and no issues then for myself (I know others did) and this 6900xt has been solid since release day. All swings and roundabouts.
Indeed but I do feel it has faded significantly over the last 3year as AMD show and push forward. I don't think many will be shouting about Driver issues come next gen (unless there is specifically any).True but rightly or wrongly, AMD has a worse reputation for driver problems. It's good that they're turning this around though.
