I'd forgotten Pan baking temp is only 165C , from diagnostics manual, equally if proving temp is 35C - I'm not sure mine exhibits that.
I'd also bookmarked link on motor capacitor change, which I should order proactively
Mine is so underused now, just being used to make the dough. With an extra prove and with the bread baked in the oven, it's so much nicer than letting the machine bake it.
Menu 15 is bake only but I'm not sure it'll work - When I tried it once before, it said the machine was too warm and to allow it to cool down first which isn't much help.
Have you tried just leaving it in for an extra five minutes? The heating element will have gone off but there's a lot of residual heat still in the machine.
I don't ever add any dough improver like olive oil or butter into my Pan machine recipe - I thought it was partly compensation for baking in the machine,
with the lower temp/slower bakes.
The newer machines with the yeast container helps if you want a delayed start I guess - that's all ?
.... however I use a sourdough starter/poolish, so wouldn't really work.
I've never needed to change a Cap yet, like I said above I changed the stat and ellement. Thats what I had to change when my old machine was playing up.
Out of interest, how much use has yours had? I used to keep a check on the number of cycles mine had done but stopped after around three hundred. It's still used roughly every other day to make dough.2nd favourite gadget after coffee machine ... now had to fix the capacitor on the panasonic bread machine ... which was no longer kneeding the bread very powerfully
about £4 on ebay about 15mins, plus 30min dissasembly, belt seems to be fine
Thanks - The five hour cycle is the one I use all the time but I switch off after four hours so it never reaches the bake part.About 2 times a week on 5hr wholewheat & once on 2:20 dough for 7 years in this regeneration ... so > 1000
looks good - whose flour do you use - one loafs gone pretty quickly do you make several, electric costs considered.Have been working on my sourdough starter for what feels like months now, finally got round to some actual baking.
Just using bog standard supermarket plain flour atm. Though if I feel like keeping up the habit (I suppose more than 1 loaf a week) then I'll do some bulk online ordering and look for something higher quality.looks good - whose flour do you use - one loafs gone pretty quickly do you make several, electric costs considered.
I wonder about starting a new starter to see if the flavour could change much, had it 20 years, one day need to walk into town bakery and see if they'd give me a sample, havent't found colleagues/friends that are into it, despite the supposed covid furore ( I wouldn't contend buying one from an online site though )
that's true I'd have the same starter issue - I don't have cast iron pan so a baking steel would be my approach , if I wasn't using the convenience of a bread machine (but it does sacrifice quality)Only one loaf at a time at the mo, and you are right they do go quick! I wouldn't mind doing 2 at a time RE oven cost yeah, but means maintaining another starter (or I suppose a bigger one, in a bigger jar), another banneton, another cast iron pan.
yes 2500 - good idea finding a probably cheaper cap in different form factorI made a spare with another type of capacitor should I ever need it for my SD-ZB2502.
What model is that 2500 ? looks like the same cap.
after seeing the effect of cap I may well change the themostat too, on the grounds it has deteriorated - subjectively never seems very warm during proofing - where did you buy from.
I always make medium 500g loaves, but have not experimented with using small/large options to see if that would modify the bake in a useful way ?
I know we talked about it before but have you tried baking it in the oven? I was proper happy with bread out of the machine until I started using the oven to bake the machine produced dough.Set a timer for 29 mins, after the machine has stopped de-gassing 1:20 remove the dough and paddle shape the dough into a ball then return to the pan.
yes I do that 1hr on wholewheat option, and, about 1hour before the end, befor 47min baking cycle I slash the top.Start..
Set a timer for 10 mins, clean down the sides of the pan at
