I take it the one per household will be reset when the 40xx series is out ?.
It will definitely reset - they dont want people scalping, they want as many people to have their brand as possible. If they don't reset, then they're saying anyone who bought this 3000 gen can't buy into their new gen... that would make no sense at allI take it the one per household will be reset when the 40xx series is out ?.
Not sure if I can be bothered to upgrade as really satisfied with a 3060 ti FE at 1440p Ultra settings.I think the question isn't whether you'd be banned from getting a 4000 series, more whether you could buy another 3000 series (assuming they were still being made).
Yea but how about vram bro? Bet you feel bad missing out on playing Godfall and Far Cry 6 maxed out!Not sure if I can be bothered to upgrade as really satisfied with a 3060 ti FE at 1440p Ultra settings.
I have had nearly every card of AMD and Nvidia this generation and I can say I was most disappointed by the 3090, 6900xt and the 3080/6800XT as at 1440p there was max 15-20fps difference compared to 60ti FE.
This is only at 4K! I play at 1440p so no need for >8gb vramYea but how about vram bro? Bet you feel bad missing out on playing Godfall and Far Cry 6 maxed out!![]()
Some people willThis is only at 4K! I play at 1440p so no need for >8gb vram
Same here with my 3080 and 3070 systems, not much between them, drop two maybe 3 settings down one notch on the 70 and they run the same fps.I was a little surprised at how little difference there was between the 3080Ti I tried, the 6800XT and then the 3070
