Poll: *** The official 2022 MacBook Air/13" MacBook Pro thread (it has the M2 chip, MagSafe and everything!) ***
What 2022 M2 notebook will you get?
  • MacBook Air
    Votes: 35 87.5%
  • 13" MacBook Pro
    Votes: 5 12.5%
  • Total voters
    40
2 Feb 2006
I'm in two minds about what to get... I had pretty much said to myself the M2 Air will be all I need and have been waiting for it to come out, but today I went to an Apple store and saw the 14" Macbook pro M1 in the flesh for the first time and thought it was great, happy with the size and weight, etc. When I spec the M2 Air id get (8 CPU, 10 GPU, 16Gb Ram & 512Gb SSD) it comes to £1,749, so now I'm thinking may as well just pay £1,899 for the M1 Pro (8 CPU, 14 GPU, 16Gb Ram & 512Gb SSD).
I am upgrading from a 10 year old Macbook Pro (Mid 2012, 2.9GHz Dual-core i7, 8Gb Ram, 512Gb SSD) so whatever I get will be a massive improvement over this, and to be honest, it's not like my current Macbook is terrible, my main use is Office, web browsing and a bit of gaming when working away, so I know both are overkill for my needs but as this MacBook can no longer get OS updates (its running Catalina) I will be 100% get one of them as an upgrade and just give this one to my GF.
Either will give a massive speed increase over my current model. I guess the only advantage the Pro would give me is better options for gaming, the HDMI port is also a bonus and would save having to use any adaptor when giving any presentations. Need to see the M2 in the flesh now! Will they be in the shops before the release date?
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
Ah, nice! Thanks, I will keep that as an option if I decide on the Pro.
Will be really interesting to see how the M2 compares to the M1
The 14" has the Pro chip too, more ports, better screen, better speakers.
For the money vs a specced up M2 MBA, unless you ABSOLUTELY have to have the thinner form factor and the midnight colour. I'd take the 14".
  • Like
Reactions: LiE
2 Feb 2006
Yeah, I was really impressed with it when I saw it in the store. I'm going to hold off buying anything until I've seen the M2 Air.
10 Apr 2013
I guess the other question is how long we have to wait until the 14” MacBook Pro is updated with an M2 chips?
At least with the m2 air you know it likely won’t be updated for another 18 months or so.
Apple really are the masters of upselling though as by the time you go 16Gb/512gb with the air it’s very close to MacBook Pro pricing :D
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
But then you’re looking at £1899 or maybe more and unless you’re actually making use of that 10s export time reduction (not actual example) or proRes capabilities it’s all just the same day to day.
10 Apr 2013
Yeah, personally on balance I’d rather have the m2 MacBook Air for the better single core performance, lighter weight, better battery life and the cheaper RRP sticker price.
I can see why some would go with the 14” M1 Pro for the better screen, multi external monitor support, faster GPU and HDMI/SD card ports though.
2 Feb 2006
This is my issue. if I'm being honest the air is overkill for what I would need 80% of the time, so would be absolutely fine. But then the Pro has the better screen, more ports, and is the better option for gaming (I assume, I know neither are made for gaming but gives better options looking at what the pro can do).
Man of Honour
20 Sep 2006
In all honesty you are very unlikely to notice any difference CPU performance wise. The base M1 is blazing quick, the M1 Pro even more so. You will however notice the screen as you look at it all of the time plus the ports. I would not be considering the new Air unless portability was at the top of my list. Being able to plug in the sd card from my Go Pro was bliss, without cocking around trying to find an adaptor.
  • Like
Reactions: LiE
3 Dec 2012
Northern Ireland
Yep as above. Don’t discount the screen on the 14/16 models - it is sublime. I spent most of last summer trying to find a monitor that would be a good addition for my MacBook (but also for gaming on my PC) and settled on the Alienware 34. Since I got my 16 MacBook I may have used the monitor once - the screen is just THAT Good.
10 Apr 2013
Difficult to make a fair comparison right now as we still don’t know the exact performance of the m2 nor the battery life or how the display compares.
I take it there’s no date for the review embargo yet?
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
What is your intended use? Performance of the base M1 is already enough for 99% of people.
8 Oct 2020
I think if someone cared about the performance uplift on the M2, they'd be looking at the Pro M1 models instead.
