I've checked both, they both read the same.... its bad. I think even at default bios settings it reads this value. I've checked Tech Powerups review of this board and again it shows the same value too.SA at 1.648v is def going to degrade your CPU if that is real. Check hwinfo64 in OS and see how it actually reads. Hopefully it's just a bios bug.
VID is what your CPU is requesting, what's it's getting is what what matters. Unless asrock really f'd things up, you don't need to touch your vid.
For DDR5 since the mem controller is running at half speed, gear 2, you don't need much SA at all. Stock SA on z690 is 0.95v which is plenty for what you're running.
https://docs.google.com/document/d/1HJnQnRtgvkJ329tQemyiWawclISV-u9wON0jpNoQZJ4/edit it's a work in progress you can get ideas of DDR5 voltages, timings and tuning here.
Probably not what you want to hear but never buy asrock for any form of OC or tuning. Infact, don't buy asrock in general.
Thanks mate, in that case i'll leave my CPU SA VID alone then at default voltage and just tinker with the VDD and VDDQ voltages + Timing.
Abit annoyed with ASrock with this, how can they set a voltage that high and not realise? I'm tempted to send this board back and just pay the extra for the Asus itx board but its an extra £50
