BT Infinity & FTTx Discussion
Man of Honour
20 Sep 2006
Code:
[root @ untangle] ~ # ip a | grep peer
    inet 82.69.112.207 peer 51.148.77.133/32 scope global ppp0
traceroute to bbc.co.uk (151.101.0.81), 30 hops max, 60 byte packets
 1  lo0-0.bng5.thn-lon.zen.net.uk (51.148.77.133)  13.015 ms  12.979 ms  12.965 ms
 2  lag-15.p2.thn-lon.zen.net.uk (51.148.73.100)  11.686 ms  11.675 ms  11.660 ms
 3  lag-2.p1.ixn-lon.zen.net.uk (51.148.73.133)  11.640 ms lag-1.br2.ixn-lon.zen.net.uk (51.148.73.169)  11.618 ms lag-2.p2.ixn-lon.zen.net.uk (51.148.73.139)  11.602 ms
 4  * lag-1.br2.ixn-lon.zen.net.uk (51.148.73.197)  11.575 ms *
 5  * * *
<snip>
30  * * *
I sometimes get given the .129 gateway also but I don't get those pings. I used to!
If it's a recent line you may not be able to see, but look in Zen under my orders > order history:
Zen FTTP GEA Migration
zen******@zen Fulfilled on 22/06/2022
Edit, same gateway after a few poff/pon.
Code:
    inet 82.69.112.207 peer 51.148.77.129/32 scope global ppp0
[root @ untangle] ~ # ping 1.1.1.1
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
64 bytes from 1.1.1.1: icmp_seq=1 ttl=59 time=11.6 ms
64 bytes from 1.1.1.1: icmp_seq=2 ttl=59 time=11.1 ms
Man of Honour
20 Sep 2006
I have nothing like that for ether of my lines (FTTP / FTTC)
You might be lucky. I've got on the same gateway as you and whilst I don't expect to get the same ping as you, I have had <5ms prior to being migrated. Maybe the migration does something between the exchange and the actual gateway, I'll need to read up on it and see if there's any info.
18 Oct 2002
Manchester
This is what I'm seeing when tracing to bbc.
Code:
Tracing route to bbc.co.uk [151.101.0.81]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  amplifi.lan [192.168.154.1]
  2    12 ms    12 ms    12 ms  lo0-0.bng1.ixn-lon.zen.net.uk [51.148.77.128]
  3     9 ms    10 ms    10 ms  lag-3.p1.ixn-lon.zen.net.uk [51.148.73.85]
  4    10 ms    10 ms    10 ms  lag-1.br1.ixn-lon.zen.net.uk [51.148.73.181]
  5    10 ms    10 ms    10 ms  195.66.225.91
  6    11 ms    10 ms    10 ms  151.101.0.81
2 Oct 2004
South East
I am also on Zen and do not have the major issues others have, but its interesting to note a connection on the same PON as me (same street) has half the latency via Talktalk.
ZEN:
Code:
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=6ms TTL=118
Taktalk:
Code:
Reply from 8.8.8.8: bytes=32 time=3ms TTL=59
RSR
RSR
17 Aug 2006
What are the thoughts on Talk Talk, as I may move my FTTC (Fibre 65) connection to them? Do they use PPPoE on FTTC? It's not really used for much now it's just there for a backup now.
9 Mar 2003
Here’s my talk talk review:
Backhaul: solid, never any slowdowns
Price: Good
Supplied equipment: reasonable
Support: never used it but probably **** like all mainstream ISPs.
Complaints: none.
I’m not sure what they use on FTTC, but my FTTP is DHCP.
  • Like
Reactions: KIA
13 Jun 2007
London
Hate to say it but I think this has made my mind up to avoid zen for my fttp order next week. I was still considering them even though they were pricier but this GEA migration business seems to be a bit of a potential headache.
Think I’ll give Vodafone a shot
Caporegime
18 Oct 2002
I'd rather TalkTalk than Vodafone. At least with TalkTalk you can post on their forum and someone who isn't a complete idiot will help you. Vodafone just tell you to Tweet them.
V F
V F
13 Aug 2003
UK
Who would have thought twitter became a help support line for companies.
Caporegime
18 Oct 2002
It's ridiculous that companies expect you to sign up for accounts with US social media companies to get help with their services. What's wrong with running a service desk that you can email? Why the obsession with live chat or phone calls?
Man of Honour
20 Sep 2006
Aquiss or maybe Cuckoo and pay them for the static IP. I find it hard to recommend Zen at present. I’m currently on a gateway with 24ms ping.
RSR
RSR
17 Aug 2006
To add some postivity to Zen, my FTTP line with them has been in for just over a week now and has been flawless, really pleased with it.
My UDM SE should arrive today, so ill get that swapped over later as I have a script to correct the MTU issues on that.
Latency on its has halfed from my FTTC connection and COD updates now take seconds / minutes rather than hours.
Code:
Reply from 8.8.8.8: bytes=32 time=3ms TTL=116
Reply from 8.8.8.8: bytes=32 time=4ms TTL=116
Ping statistics for 8.8.8.8:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 3ms, Maximum = 4ms, Average = 3ms
Once Lightspeed finish installing ill, compare that against Zen.
7 Jun 2020
TalkTalk are £49 a month for Fibre 900 with a £100 gift card and then add on £112 cashback via Quidco and you are down to £37 ish a month.
That actually sounds pretty good I wonder if it applies for CityFibre packages too. I'm with Vodafone, I don't & have never had any issues with the connection itself as it's FTTP.
It's just the support that is a bit lacking - mainly billing issues when changing contract etc, not sure how much better things are at TalkTalk.
I also wonder how different the latency would be, one of the factors that makes me reluctant to switch now to any other provider.
