- 20 Jul 2009
- The bleak North East arm pit of Britain
Maybe not exactly the same but I currently have 2019 13" Macbook Air and a 6 year old desktop PC. I'd like to ditch my desktop PC but I'm finding the 2019 MBA isn't really powerful enough for my needs. So my current plan is to sell the 2019 MBA and buy either a new M2 Macbook Air (16Gb/512Gb) or a 14" Macbook Pro (16Gb/512Gb). I have a 34" (3440x1440) monitor which I'd dock with a future Macbook so I can use it as a desktop relacement when I need a larger screen.
Trying to decide whether I'd be better off with a Macbook Air M2 or a 14" Macbook Pro M1. I'm erring towards the M2 MBA as I prefer the lighter form factor and it's likely to have a better battery life. I'm wondering how long it'll be before Apple update the Macbook Pro with an M2 Pro chip? I'm thinking that's probably another 5-6 months away though.
Given release cycles I wouldn’t think thenm2 pro or m2 max will come until next April or so giving it 18 months.
All the reservations I have with the air you’d have covered with the ssd and ram upgrade I would like to think but that that point you are only £100-150 away from an m1 pro 14” base. The screen will be no end better and the added speed will keep you going a year or two longer. I don’t think the air will be worth the money at that tipping point. If it was say £1500 at that spec rather than £1650 I’d say it would definitely be worth it.
