consider supermarket ownbrands as well, the variance in the macro breakdown is very small from the premium banded stuff to the Tesco's own stuff for example.It looks like peanuts will save me a fortune. 40p per 100g vs £1 per 100g on the mixed nuts. Good shout![]()
But a double portion bowl of cereal is more quantity then the porridge I've suggested. Ok there's the issue of you not being a fan of porridge so that's a different matter but if volume is your issue you need to focus on what's calorie dense, maybe you really need to focus on upping the fats, consider a keto style diet.
yeah i am not to worried about perfect PL comp form as i am not interested in that. Good to hear CheersIt wouldn't pass in a PL comp but as a gym 1RM I'd be happy with that.
. If I fussed over every tiny imperfection I’d never have progressed.yeah i am gonna try it again in a few months without the bounce and see what i can do. Think my arse came up a bit as well for a second which i can change. I am happy with it thought since i only started training around the end of February.A tiny bit of a bounce, but you moved it. I’d take it for a gym PR, your form is tight enough. Comp lifts have never bothered me anyway. My mate competes and half the stuff they green light him on I’d disagree with. If I fussed over every tiny imperfection I’d never have progressed.
Now my goals are to rep 100kg by the end of the year for 5 rep
at the moment i am repping 85kg for 8x4
I would love my squat to go up to 120 minimum and my deadlift to rise to 150kg
I cut in 2 weeks gonna be sad seeing my numbers go down but its worth it for the shreds.
Thanks for the responses guys i appreciate it. I don't often post here but i am always lurking![]()
yeah your right i am not worried about it since although i enjoy results and numbers at the end of the day I just enjoy turning up to the gym and giving it my allYou’ll no doubt find that progress will slow significantly in due course and may even reverse at times. That’s the moment when your mindset really counts.
Honestly I think that was actually very good. You probably just need to tighten yourself up a little (hard to tell from this angle) but you could slow it down and with the right bracing/form I bet you could do it with no bounceHi Guys,
Would you count this 1 Rep 100kg bench. Looking back on it I bounced slightly off my chest. Your opinions would be good to hear.
Thanks
My 100kg Bench
Hi,Honestly I think that was actually very good. You probably just need to tighten yourself up a little (hard to tell from this angle) but you could slow it down and with the right bracing/form I bet you could do it with no bounce
Great work mate - 100kg is a great milestone.
HI,Yeah a nice decent 100kg there @Omega_ . When it comes to cutting don’t expect your lifts to go backwards. They really shouldn’t. They might not progress as quickly or even stay the same but your overall strength if managed correctly should remain stable.
How long and how aggressive of a cut do you have planned?
Hi,Your plan sounds very sensible and on a similar level to what I’ve done this year to drop weight, except you get to eat a lot more then I did haha. I’m in the phase of reverse dieting my way up to my new maintenance, after my cut ending up at 1650.
Although you don’t need fats to keep you full, carbs and protein are much more satiating in general and that should be your focus for hunger control.
Protein keep at what your saying or 1-1.5g per 1lb bodyweight, fats 30-60g per day and fill the rest of your cals with carbs. Target for 60g fats in that range 30 being the bare minimum.
