Tell me about it, I spent that on some E10 at Morrisons after the weekend ride to Devon. I remember the days when I would probably spend £30 - or a smidge over, for the days ridingYep, bit of warm weather and the number of younger looking guys I'm seeing without any gear, crazy!
Just paid 31 quid for 15 litres! 205.6 for BP E5. Never spent that much filling my bike up
Then went for MOT, fine 30 quid but 12 months tax seems to have gone up again too!
Run the bike for a minute, let it settle, then check it again. Is it on a completely level surface and does the paddock stand hold it level?I have a riddle for you all.
An XJ6N takes 2.8 Litres of oil (when replacing the oil filter.) Let's say you remove the sump plug you drain maybe 2 litres of old oil out plus remove the old filter. Then replace the plug and replace with a new filter, and add 2.8Litres of liquid gold, why is the dipstick bone dry except for the absolute smallest part right at the bottom of the stick? Bike has had about 3 hours to drain and is stood upright on the paddock stand. My question to you, is...where has the oil gone..?
Yeah I'll be topping it up today. 100% level surface and paddock stand is perfectly flat. I didn't fill the filter otherwise I'd have dropped oil all over the floorRun the bike for a minute, let it settle, then check it again. Is it on a completely level surface and does the paddock stand hold it level?
Also, did you fill the filter before fitting it?
I really need to try Calimoto.Wife had her first ride on her Vespa this morning, her bike control is shocking, she almost binned it twice in our car park. Once up to speed she's fine, but the nerves get the better of her at low speed. Tomorrow we're going for a little ride again, I know she can do it as I watched her on her CBT, she just really doesn't want to damage the Vespa.
We drove to Brighton today in the car using Calimoto so she could see what I'm always banging on about and she loved it, so that's good.
Saw a couple of crashes too, one was a pretty gnarly looking bike crash, looked like a car pulled out on a Street Triple and he t-boned it, hope he's ok
The other one was a car-only incident, a Fiat 500 which was on its roof in the opposite direction of the motorway we were on, it looked seriously nasty. It never fails to amaze me how many accidents we have on these busy weekends, hope everyone's ok.
Always put E10 in my sv, can't say I've noticed a differenceEewwwww
accidentally put E10 in my SV650, feel dirty.
Apparently it will be fine, but must use that tank up asap!
Think it’s more long term usage and storage on older bikes as the ethanol absorbs or turns to water over time?
