Would you want gen 4 PCI-e? Be silly not to really with a 5900x
Not to fussed about that. Does it make any difference if I just game?
Direct storage is coming soon and will begin to be implemented into games. So a gen 4 M2 drive is more of a future proof option for you. And they don't cost a whole lot more than gen 3 now. So you want to be looking at b550 boards. You'll get one gen4 m.2 off the CPU and the 2nd is off the chipset and gen 3.Not to fussed about that. Does it make any difference if I just game?
and I've not had a PC for 3 years. Does it need to be matx or ATX? And what's your budget?Ah, knew nothing about this. I've been out of the loop for a long time. wife, kids, work getting in the wayand I've not had a PC for 3 years.
Is there anything that you would recommend that will do the job but also usually sells at a good price?
ATX. No budget. Cheaper the better. I just want something that will run it really.
Quality power delivery without a crazy price tag. There's a b grade for £120 too. Or if you wanted sub £100......![]()
MSI MAG B550 Tomahawk (AMD AM4) B550 ATX Motherboard
Order MSI MAG B550 Tomahawk (AMD AM4) B550 ATX Motherboard now online and benefit from fast delivery.www.overclockers.co.uk
My son uses this board with his 3700x.![]()
**B Grade** Asrock B550 Phantom Gaming 4 (AMD AM4) B550 ATX Motherboard
Order **B Grade** Asrock B550 Phantom Gaming 4 (AMD AM4) B550 ATX Motherboard now online and benefit from fast delivery.www.overclockers.co.uk
Ye, just update to the lastest bios with the new 1.2.0.7 coding and new chipset driver from from AMD.com and you'll be good to go.Thanks for the help. I'll probably grab the cheaper one if it will do the job.
B550 Tomahawk at just over £100.If I got a 5900x and the budget was as tight as a nuns, what board would you get? A cheap used one would be good.
Thanks for any advice.
A 5900x uses no more power out of the box than a 2700x. 12nm to 7nm power savings. 4 cores within the same power. A 5950x is better binned silicon so 16 cores at the same power. Are you planning on just running the CPU at our of the box settings?Would a tomahawk max 2 do the job for a 5900x
Thing is. I found someone selling a 5990x cheap as chips. Now I'm picking it up from there house so if there is something wrong it's going back. But wanted to pick up a cheap board just to test it. Then I was thinking of selling it and getting maybe be a 5800x or even just disabling some core if that can be done. Want need all them core or the beat to go with it.
Curve optimiser might be an option if you wanted to run it as lean as possible. Ryzen master has it built in to save hours of manual testing. It tests all the cores over almost 2 hours and sets them at less voltage to run cooler at stock speeds. Which cooler where you planning on using?Yeah I'll run it at stock.
**B Grade** MSI MAG B550 Tomahawk (AMD AM4) B550 ATX Motherboard
Order **B Grade** MSI MAG B550 Tomahawk (AMD AM4) B550 ATX Motherboard now online and benefit from fast delivery.www.overclockers.co.uk
Play the OCUK B-grade lottery lol.
If I knew this CPU was good I would probably buy that. But I've found a b450 tomahawk max 2 for £40 so if that will do? It's not a big loss of i end up stuck with that or need to sell that on.
Do I now have to either set that In the bios or run RM every boot
