Nearly got mine setup how I want it. All the console machines work. The Experimental ones still cant seem to get to work. (For CD32 use the one in Console, set the CPU to -600 and it seems to run them better) Added all the Ports they all now work, (Doom, Quake etc) All the images are downloaded for all the games that have them so when you view a game you get the box art, cartridge (if it had one) and screenshot. Plus I found a load of apps that have been written. The instructions/description are in chinese but you can still use and translate it. The instructions are easy you just unrar the archive and copy the folder within to the App folder. Some interesting ones in there such as motor test, nannoid (free version of Arkanoid), bfruit (colourful slot machine). One that is interesting is CPU Freq. It lets you change the CPU clock so you have 4 modes. Performance (1200mhz) OnDemand (auto clocking up/down this is the default) Userspace (not sure) Powersave (400mhz). Last but not least sm64_port but I will let you find out what this one is
https://github.com/steward-fu/miyoo-mini/releases/tag/stock
