Yep.
Cool. That is what I really want but depending on speculative dates I'll probably just get a decent one to start with and then see if I feel it's worth upgrading.
Going to get a decent motherboard this time around, I usually go middle.
Yep.
Is it just me or is the hype for zen4 just a bit flat ? seems like AMD really did a job on themsleves with their claims of mediocre performance up lift and yet all the leaks (which I know can't be trusted but when they are all pointing the same way its hard to ignore) seem to suggest that AMD are about to launch a really great CPU lineup. Even on here, with only about a month to go, there would normally be hundreds of pages of chat and speculation. I not long ago upgraded to a 5600x, but the AM5 platform is starting to look like a real good one to jump on.
Im sure I read somewhere there is some kind of announcment from AMD today, is that right ?
Depends where prices end up.Has AMD confirmed if the B650/B650E boards will definitely be launched this year?
Not really bothered about the X670 boards, since it looks like they will cost £200-£300.
Does anyone else think the same, or are you happy to spend a lot on a high end AM5 board?
I wonder why there have been so few USB 4.0 boards announced? I'd expected more X670 boards to support this feature, considering the age of USB 3.0.
Maybe USB 3.2 is considered to be enough of an upgrade for many customers?
Never had an Asrock mobo, something always put me off them and I always stuck to Asus/gigabyte/msi.
I would avoid cheap ASRock boards, I have one (just £70) and they used low spec parts for the VRM. I would have thought the high end boards are fine though.
