Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Thank you mate. Can you show a photo of it in action? Just wanna see if the angle will be suitable.
Maximum, it's JUST shy of 90 degrees.
When placed down.
Minimum, and it can do everything in between. Smaller than this it will "snap" back into place. In between there is just resistance from the hinge, so it's stepless.
I would have preferred put it dead center but it's too long without covering the Valve logo or without sticking out the bottom so the choice was either side of the logo. There is enough space without blocking the intake vent. It comes with a spare 3M strip so I can move if it need be.
The stand is made of metal so it's pretty solid. The Deck still fits into the case that it comes with still attached. I did consider whether it put any pressure on the stick inside the case but it's hard to tell, it feels okay to me, certainly doesn't make closing any more difficult, nor does the pressure, if any, causes the "click" in the stick to happen.
