Have you got thermostatic radiator valves on your radiators? If yes, get tado°. You can get smart TRVs and then control rooms individually. Should be big savings by doing that this winter.I think I need to look into a smart thermostat solution. Unfortunately I know less than zero about central heating and how it works at this point
I'm guessing you'd recommend tado - are there any other solutions worth looking at?
