It's never very clear, but I thought eBay automatically took that in to account and added it on?
Goods shipped to the UK from abroad
Effective 1 January 2021, eBay is required to collect VAT on certain orders delivered to UK addresses:
- Orders up to £135 sent from outside the UK
- Orders of any value where the item is located in the UK, but the seller is not a UK seller
For higher value items, VAT and duties are also likely to apply. However, VAT on purchases valued at over £135 will be payable directly to the UK customs authorities by the buyer.
Just found it, the last line is the catch - that's a pain!
Worth keeping an eye on this Ebay store for Victron gear, as when there is a 15-20% discount coupon, they are very often included.
I've had both my smart shunts and 2 MPPT controllers from them when there was a Ebay discount.
Security measure | eBay
www.ebay.co.uk
@Journey Nice one, was just about to Google to see what I can find, thanks. Unfortunately can't purchase the inverter(s) until I've talked to the electrician and decided which way we're going.
I can make room in the garage for two Multiplu II 48/5000s, especially at a saving of £575 and no external anti islanding, although there will no doubt be extra electrical work.
Are you going whole house back up?
How are you doing your anti islanding?
As far as I can tell the Quattro doesn't have anti-islanding and it therefore needs an external system
Question now is which is better, single Quattro 10000 or two Multiplus II 5000's?
