EV general discussion
Status
Not open for further replies.
you are probably paying extra for the 10m in addition to the 6.5, if you only think you need 7 it'd been worth dummying up a length of hose or something at the stock 6.5m to see if it would do first, assuming you haven't done that already, I should have done this :D
Yup grants are gone and other costs have gone up. Zappi unit is ~800, 10m cable about £150, never mind the additional bits that might be need from consumer unit. Hypervolt is cheaper.
@Simon there is no way to tell if that is an excessive price or not without knowing more about the installation itself, it could be simple in which case £1300 is a lot, it probably isn't straight forward (few are in reality) in which case its probably fine.
The charge point is £800+ plus materials and sparks round here charge £70+ an hour. It took them more than half a day to install my Hypervolt so they wouldn't have been going on to another job that day.
Indeed, although the way I looked at it is that the cable/installation is going to be in the house for decades so it’s not like you are a amortising the cost over your initial ownership period. EVs aren’t going to go away anytime soon.
But you are if you move house
Indeed but it’s swings and roundabouts.
When the housing market gets back to being somewhat more stable, it will probably make your property easier to sell. Same goes for solar.
Houses with charge points or have the ability to have one easily installed (E.g. off street parking) will command even more of a premium than they do now.
No different to a quooker tap or built in appliances tbh. Just the cost is insane if you ask me. Electric showers seem to be no effort and seems it’s a EV owner tax tbh. £700 for a fancy switch. But hey
Oh that price was the hypervolt. Not Zappi sorry. Too much going on
I think it’s fair. As a new CU is £145 just something to consider. (Plus I need to get DNO to unloop)
Did the labour quote change for a shower install in your driveway? :p
Status
