- 19 Feb 2007
- Northampton
I'm using the same card - I set it to 1980 MHz @ 925 mV with a 75% power limit - it's been pretty darn stable.
I shall try it
At 75% power (1980/925) there's pretty much zero headroom for memory OC'ing (it'll drop clocks if you do) - and, to be honest, it's not necessary - I added +500 to the VRAM just to get a nice, round 11000 MHz out of it
If I let my 3090Ti run flat out with stock settings, it peaks at 1995 MHz and 450-ish watts - with those settings, even at 4k and an uncapped framerate, it shouldn't use more than 350W.
How you set the specific voltage like that? Can you show you curve?At 75% power (1980/925) there's pretty much zero headroom for memory OC'ing (it'll drop clocks if you do) - and, to be honest, it's not necessary - I added +500 to the VRAM just to get a nice, round 11000 MHz out of it
Thanks. Do you leave the starting parts stock?
Thanks Dice. Have applied the settings. Will have a go on Div 2 tonight as that's the one that seems to crash my OCs normally. Should be a good test.Yes, Click, Hold and drag the very far right square down to the clock you want while also holding shift, In my case roughly 1980, Then drag the little square over the voltage you want up to the clock you want, Again roughly 1980 in my case, Click apply on the main Afterburner screen and it is then set, Just make sure to save it as a profile 1-5 and then also adjust max power.
Div2 is an absolute *bitch* on overclocks, any weakness in your system at all and that game will pick it up.Thanks Dice. Have applied the settings. Will have a go on Div 2 tonight as that's the one that seems to crash my OCs normally. Should be a good test.
That is exactly why I use it. I know if it's stable on Div 2 I'm golden lol.Div2 is an absolute *bitch* on overclocks, any weakness in your system at all and that game will pick it up.
Well that's impressive. An hour on Div 2 and no crashes. Average of 100w lower and 10c lower too. Is there any downside at all!?
2hrs is my benchmark usually, I've had it crash at 90mins and beyond.Well that's impressive. An hour on Div 2 and no crashes. Average of 100w lower and 10c lower too. Is there any downside at all!?
Running my 6900XT at 240W atm and the clocks are still good (circa 21k TS) and perf more than enough for 1440pNot really, You won't have as high of a boost clock but shaving off maybe 2-3FPS is well worth 100w lower![]()
So my not too distant financial situation took a turn for the better, Managed to get a job that my qualifications can actually earn me some money in while I wait for my course to earn my physiotherapy qualification next year, My first pay packet isn't for another month but I had a little put aside which I used to buy my ex work mates 3090 Ti for 500 clams, Which is crazy low I know, And he threw in his custom CableMod 12 pin, He wanted rid of it quickly due to moving country with his wife, He sold his 12900K, Motherboard and DDR5 memory in a bundle to another workmate for £300, Absolute madness !
Anyway loving the performance, Got a nice undervolt going too so in my current main game of The Witcher 3 at 1440P max settings, Mods up the yingyang, I see around 170watts at a locked 60FPS
Running my 6900XT at 240W atm and the clocks are still good (circa 21k TS) and perf more than enough for 1440p![]()
Welcome and on TROH.![]()
I'd be interested in one myself if they hadn't recycled the 3090FE cooler and left it as-is (where most AiB's improved their's). Wasn't impressed with that tbh, could do with even a slight improvement imo (although I've not used so not a personally informed opinion).The 3090Ti FE is down to £1100 on Nvidias own store, Crazy low price considering what it started out as.
