- 13 Jul 2004
- Stanley Hotel, Colorado
BP and Shell are global corporations. You cannot nationalise them not just because they are big, they arent required to be in the UK its their choice they can avoid us altogether. Every idea of we will use force, make a law to say you must agree to this measure is failed logic, failure in business.
USD is the world global reserve. GBP makes up something like 7% of world central bank reserves perhaps? By default you could be correct
The UK went broke in the 70's and IMF bailed us out, if you look at our debt profile its extremely different to USA. That potential difference can mean we are the ones with higher rates vs USD which is leaning on its world status
US Fed are going to take on a very aggressive monetary tightening policy which will see interest rates ramped very high, and with QT, will make the USD much stronger. The UK and EU are not going to be anywhere close to the Fed in terms of rate rises
The biggest constant use of energy will be the freezer, the seals often go on them so its on far too much trying to cope with air entering. I think some sealant is in order, I know its something I have to do myself. I'll go round it with a silicon gun, leave it overnight at least and it'll retain a lot of that barrier even when actively opened and closed I think. Or very simple put some old plastic bottles of water on top if its only slight. It wont show up immediately (but theres a lot of ice formed inside where the leak is I think), thats why its missed oftenWhat are we going to do? Living alone and elderly with nobody to lean on I'm honestly sick with worry and fear just now.
Hope its a mild Winter? its almost upon us I fear.
Hard times ahead, take care all.
