Ukraine Invasion - Please do not post videos showing attacks/similar
Status
Not open for further replies.
They’re going to hit a brick wall at some point. The Russians will de fleeing to a location somewhere in numbers, where is anyones guess but I I had to guess I would say they will eventually give up dombas and concentrate their forces in Crimea as that getting taken would be the ultimate shame Putin could face.
I'm sure Ukraine would find that acceptable since they can just keep bombing the **** out of Russian positions all over Crimea, cutting them off completely by disabling the use of Kerch bridge and making Sevastopol irrelevant as a clear water port through being unable to use it.
I'm sure Ukraine would find that acceptable since they can just keep bombing the **** out of Russian positions all over Crimea, cutting them off completely by disabling the use of Kerch bridge and making Sevastopol irrelevant as a clear water port through being completely unable to use it.
Indeed, Russia has no answer to the equipment being used against it. Ukraine can just sit back and hammer them as they have been elsewhere.
This was probably the most likely next step. Send the full force. It will make the traffic jams of the last one look like nothing. No surprise Russia would go for the brute force step. I wonder if they are going to start a wider conscription of Russians.
What equipment are they going to send the full force with? they ain’t going to do much damage with 1 mosin-nagant rifle between 2 and 10 rounds to use and T54 tanks and 95mm field guns, the times of throwing endless numbers at a front is over, it’s now quality over quantity
He’s truly lost his mind if not. Their military has been significantly weakened, sanctions have meant they can’t replace the crap that they have that is clearly completely outmatched, they’ve pushed several countries into NATO, have forced NATO to rearm, made Ukraine a country that we have no choice but to pour money into and eventually pull into NATO if not officially but in terms of future support and have forced Europe to get their energy elsewhere. Impressive.
And probably devalued their arms exports as the rest of the world can see it isn't effective against most of the Western arms.
Definitely not enough equipment but it may be about defence rather than offence now to stop the loss of land. I wouldn’t be surprised if they are just going to march forces through Ukraine. It’s such a vulnerable position for Russia to be in now. They have a lot of land disputes with other countries who may just take advantage of this situation.
You have to think, are they withdrawing as pretext for a nuke or two. It's got to becoming more likely if nothing more than to save face
I think the fact that it goes against their doctrine and what’s left of their allies would turn against them and the majority of the Russian population, that’s very unlikely. Although it’s not impossible
Hopefully someone sane would off Putin before that happened. Also it seems more of a rout than an orderly withdrawal.
Status
