- 2 May 2011
- Woking
Currently optimising my system before the winter.
I've fitted a tempetature sensor to the output and return to my combi boiler - I'm looking to balance the radiators so that the return temperature is as low as possible.
Approx. efficiency on a condensing gas combi is:
> 54 = non-condensing mode = 87% or less
50 = 90%
40 = 94%
30 = 97%
20 = 99%
Sadly, my system seems pretty poor with the return temperatures, but that's with all the radiators full open. I had hoped that shutting off the bathroom towel rail / radiator would help (they're known to give off little heat, therefore return high temperatures and destroy the condensing efficiency).
Currently = 52'C output and 48 'C return!
Now to hunt for the radiators that are flowing too fast and returning high water temperatures...
Found the main culprits - small radiator in the single bedroom is pretty much returning water at the same temperature, as is the one in the main bedroom.
"Best" one so far is returning 44'C with 54'C input, but even that's pretty poor! It ought to be at least 12 degrees delta, but I am doing this test with an ambient of 22'C..
I've tightened down the lockshields on the offending rads and will re-test when they settle.
Radiators fully open are unlikely to give you a low return as the flow rate will be pretty high. Unfortunately balancing radiators is a task in pain - works fine in full load but when you have part load, it'll be borked.
Glad you found the bad seed though. That whole setup sounds like a big improvement. Remember, you won't get a good dT until the dT between your room temperature and the radiator temperature is larger.
I'm going to get a clip on temperature sensor for my radiators. My work sell these wonderful self-balancing radiator valves, but they're expensive. For my house it'd be £200 to fit it out, and I'm not sure that's worth it. But I will get a couple for the towel rails as towel rails are notoriously awful.
I've actually turned our heating on this weekend. It'll only trigger if the temp in the house gets too low though. I could really do with the towel rails coming on for a little bit as our towels aren't drying properly now.
A couple of years ago we had our boiler and rads replaced. A few months later I found 'urban plumbers' youtube channel where he talks about the things being mentioned in here. It annoys me that I didn't take an interest when the system was being installed because I would have made better design discissions than our plumber did.
I would have chosen a smaller boiler and openthrerm compatible (this should be a mandatory feature for all boilers fitted), I would have gone combi instead of a system boiler, but at the very least fitted a hot water diverter kit so I could run a different flow temperature for the radiators and a higher temp to fill the water cylinder (difficult to retrofit this now). I would have wanted a weather compensation sensor (again this should be mandatory) and bigger radiators. I've reduced the pump speed from highest to lowest but even so my flow/return delta is hilariously bad and there isn't really much I can do about it.
It's sad to think that this plumber was very experienced but wasn't aware, or didn't care, about designing a system to get the best out of the technology available. It's not even that hard. Think of all the energy we've wasted as a country over the decades.
Unfortunately, plumbers are generally not trained in heating system design. I had one service my boiler years ago who told me a high return temperature was good ffs! I don't think my new house even had its system balanced. Weather comp should be mandatory, absolutely.
What have you done to improve your dT?
