- 25 Mar 2004
- Fareham
That will have been true before the latest announcements, I think they may have to drop the daytime rates on Go/Agile a bit, we'll have to wait and see.
This is not for the latest one coming in on the 1st October. We have yet to receive that information.Just taken this from the Octopus web portal.
@TroopI saw this in the government's plan.
If you’re on a standard variable tariff
The average unit price for dual fuel customers paying by direct debit will be limited to 34.0p/kWh for electricity and 10.3p/kWh for gas, inclusive of VAT, from 1 October.
These unit prices have been passed to suppliers to ensure that they are used to calculate bills on time for 1 October.
Energy suppliers will adjust standard variable tariffs automatically. Customers on standard variable tariffs do not need to take any action to get the benefits of this scheme.
I also read that
If you’re on a fixed tariff
If you’re on a fixed tariff at a higher rate caused by recent energy price rises, your unit prices will be reduced by 17p/kWh for electricity and 4.2p/kWh for gas.
As Next Online V19 was something like electricity 60p per unit and gas 15p surely we'd be better changing to SVR as electricity will cost 34p on SVR compared to the 60-17= 43p if on a fixed tariff?
I hope so, just cap everything above the cap rate to the cap price, the easy way to do it.
We don't use any heating here at all and haven't had heating on since last October and yeah 1 5min shower a day is enough to use minimum of 30kWh of gas a month so really boggles mind.
Do only use around 200kWh of electric though. That I understand. Just not sure how to get gas down. The basics of some hob cooking and hot water is 250kWh a month approx
Wow that electric is low do you have solar?
exactly - we're waiting for legislation, but allowing vendors to pick&mix subsidy by reducing fixed rate tarif peak rate (octopus go say) to subsidised 34p and, simultaneously permitting a cheap overnight rate, which, that would cross-subsidise, isn't the spirit, and would cost tax-payer more,Easy, maybe. But also potentially expensive. It would basically be a blank cheque given from government to industry, with the government agreeing to subsidise any unit rate down to 35p per kWh (electricity) and 10p per kWh (gas). Some households (those that fixed fairly recently) could be seeing double (or more) the subsidy which they'll be given with a fixed discount.
Going to be interesting to see how the fixed tariff discount impacts smart tariffs. Octopus Go (at ~40p day and 7.5p night rate) currently costs me (on average) slightly less than the current cap. However, my day rate is above the Energy Price Guarantee.
I'm not relying on getting assistance by any means. I'm content (given current market conditions) with my fixed deal. But curious to see what happens.
my guess is overnight stays the same, daytime rate drops to 34p/kwh, but the news from ofgem about reducing fixed prices by a fixed amount seems random, so in theory the daytime rate could drop by 17p/kwh down to 23p/kwh which would make it sort of ridiculously OP.
And heating oil?Yeah so i've had a discussion about this and been doing a bit of digging.
The problem we have is the Gov originally came out to the suppliers and said everyone paying over the Gov cap will be reduced to the Gov cap price and anyone on a fix thats higher than the Gov cap will be reduced to whatever the cap will be, 34p elec and 10.3p gas. So the message suppliers were going out with was "Dont do anything, if your fixed higher your fix will be changed to the Gov cap price if you arent fixed then you will be on the Gov cap anyway".
The comms from the Gov to suppliers is now anyone on the SVT will move onto the Gov cap prices. Anyone on a fixed tarrif will have their tarrif reduced to a minum of the Gov cap. However if you fixed massively higher than the Gov cap you will get a reduction of 17p Elec and 4.2p Gas however you may still pay higher than the Gov cap if your fixed price was so high that even after the discount you are above the cap price.
See below scenarios
1) You are on current SVT
You will move to the new SVT of 34p elec and 10.3p gas as default
2) You fixed at 44p elec and 11.3 gas
You will see your fixed prices be reduced to 34p elec and 10.3p gas
3) You fixed at 68p elec and 16p gas
Your fixed rates will be reduced by 17p Elec and 4.2 gas and your NEW rates would be 51p elec and 11.8 gas which is above the Gov cap
4) You fixed and 1 of your rates, either offpeak elec or gas is lower than the gov cap but the onpeak or elec is higher
This is unclear and i've seen no information regarding what happens here but it would be reasonable to assume a 50/50 chance the higher rate would drop to whatever the cap price is.
There is no info from any supplier that i know of at the moment or the Gov as to whats going to happen for E7 electric customers.
Based on the above and current info. If you are fixed and you fall into scenario 3 it would be beneficial to exit your fixed price if you have low or no exit fees and go onto the Gov cap. However considering how quickly the info is changing i would wait to see what your supplier communicates to you first.
Not a clue im afraid. I work for one of the big energy suppliers and we dont dabble in heating oilAnd heating oil?
I believe its because they are using the ******** average house usage figures to work out the discount and to reduce it from the £3500 that was due in Oct to £2500 its based on x amount of kwh elec and x amount fo kwh gas and they worked the reduction from that. It's so retardedWonder why higher price fixes will only be reduced by 17p/kwh and not down to cap?
Surely most people on longer term fixes, paying (in your example 51p/kwh after reduction) wouldn't simply switch to SVR tariff on same supplier.
Boom! 34p/kwh instead of 51p/kwh.
I dont think the gov have published anything about heating oil. They did say they would cap it for the same period but not a clue on what the figures will be as i dont think even the gov know at the momentYea fair enough, your post was very helpful by the way, just wonder if us country folk without piped gas got forgotten about.
