haha .. you know not many companies can do that btw, pissin on clients while they beg for business.. ultimate power. if they can do that with customers, surely a middleman like evga got swatted like a flyNever gets old.
I think the connector max's out at 600W. so the adaptor can have a different number of 6 pin inputs.If the 4090cards all have the same plugs.
Wonder how the aib will get more power for overclocking...
Or are they all the same?
I think there is another 4090 coming soon.
Well seemingly for you it is as you've take multiple posts and page upon page to even attempt a semi coherent explanation of what you took issue with. All you had to say is something like, while Reflex was released at the same time as DLSS 2 Nvidia never put it under the banner of DLSS.
I mean it still doesn't change that it's not a 'new' feature and it even if it is it still doesn't add up to three new features but i guess if you lack the emotionally intelligence to admit to a mistake and throwing that dead cat on the table makes you feel better then so be it.
Plus like i said even if I'm wrong and Reflex was not a feature of DLSS, that it was a separate feature that was release at the same time as DLSS 2, it still doesn't change the fact that it's not a 'new'
As per your last post, it seems you are agreeing in what you said with "reflex has always been apart of DLSS before v3"..... yes or no?
Again, simple question:
Is reflex "new" to dlss v3?
All I need is a yes or no, nothing more, nothing less.
And just to clarify.... We know it's not a new "feature" for nvidia RTX users, we know that "frame generation" is new to dlss v3 and we now know that "super resolution" is just a rebrand by nvidia for the core functionality of dlss.
DLSS 3.0 is the new element, not reflex.Is reflex "new" to dlss v3?
Obviously Gibbo has responded himself, but i wasnt particularly speaking for elsewhere, i fully expected them to be taking names now (or any day now), it was more a case of knowing that if OCUK was only making them available to customers on release day, you could make your mind up as late as that, and still be able to make efforts to get one, you wouldnt have been at the back of the queue.You really think OCUK and other sites will resist the temptation to incite another gold rush by opening pre-orders once they have the first stock in?
No chance, as soon as the first drops arrive in warehouses I think websites will open up preorders.
I might go cheapest 3090 and wait for the AIO modelAhhh man I don’t know what to do for my new build.
Go FE and get a water block and try doing my first loop.
Wait for an AIO card or get the Strix.
The FE uses a unique pcb shape wth the < cut in the side so the only block that will work is the FE block from EK , i will assume like the 30 series you will also get a reference design that can be used with one block which EK will list what cards are compatible and all the rest that are custom pcb get their own blocks and they normally do it in order of how popular they are ... the Strix block was one of the 1st custom blocks they done last gen but this time they have the FE block ready to go and can be preordered now for November delivery , hopefully have a card by thenWonder if any of the “basic” cards will use FE or reference design pcb so EK waterblock will fit.
Or will have to buy FE from nvidia store to get compatibility which is annoying.
because of course what we really need is two xx80 cards launched around the same time where one is not only significantly shorter on memory but massively cut down elsewhere as well.
i think its impossible to reasonably comment on the nuances without knowing the actual model specs like an analytical representation of the model in an algebraic form, so everyones speculating on how those jargon's actually tie into the output but there's some support for new formats baked into the 40 series thats not available in the 30 series, so there might also be a fundamental change in how reflex gets incorporated into the rendering pipeline, though it would be interesting to read a whitepaper... that can help deconstruct these jargons
Strictly speaking, your question should be "Is reflex new to DLSS?"
If we're going to be pedantic...
It looks better than the PNY one at the same price.Might go kfa this time .
