- 21 Jul 2005
- Officially least sunny location -Ronskistats
None of them are your friend. No need to put either brand on a pedestal.
Expecting AMD to match Nvidias performance across the range with a £50/$50 discount, that's all they do these days. Nothing like the 4870 smashing Nvidias head in anymore.
Got excited and disappointed for rdna 1 & 2 already.
On 03.11. AMD wants to present its new RDNA 3 models, which should be much cheaper to produce for the manufacturer. By abandoning complex and large accelerator units for ray tracing and AI and switching to smaller dies, yields increase and costs decrease. For the first time in the last decade, AMD is said to actually achieve cheaper manufacturing than Nvidia, which is struggling to maintain high margins as AMD positions its new products and prepares to capture an estimated market share of more than 30 percent in the graphics card space .
Lets hope they don't this time as the goals are now double the size from their last miss. They will not have another opportunity like this in years to come.We got excited last gen launch and AMD missed the open goal.
Thanks, i'll have a good look at that later...
I'll get the coal for the train..
the AMD Navi 31 GPU with RDNA 3 architecture is expected to offer a single GCD with 48 WGPs, 12 SAs, and 6 SEs. This will give out a total of 12,288 SPs or stream processors. This is an increase of 2.4x in cores compared to the 5120 SPs featured on the Navi 21 GPU.
The Navi 31 GPU will also carry 6 MCD's which will feature 16 MB Infinity Cache per die and are also likely to carry the 64-bit (32-bit x 2) memory controllers that will provide the chip with a 384-bit bus interface.
While this equals 96 MB of Infinity Cache which is lower than the 128 MB featured on the current Navi 21 GPUs, there's also a 3D-Stacked solution in the works which was pointed out recently and that would double the Infinity Cache with 32 MB (16 MB 0-hi + 16 MB 1-hi) capacities for a total of 192 MB of cache. This is a 50% increase versus the current Navi 21 design and it also makes Navi 31 the first GPU with both, chiplet and 3D stacked designs.
This is why we badly need intel to be a success in the gpu space too, just having 2 players in it is ****, always compromises of some kind.
And solid drivers, which at least they should be as we know RDNA is entering it's 3rd iteration, likely not a worry.All AMD need is a good product, available on the shelf at quatity and cheaper than Nvidia.
Yeah stay under your rock mate.Drivers been equal with a better user gui than nvidia for years now
Hahaha, my rtx 3090 laughs at youYeah stay under your rock mate.
