yea it equals heatTemperature does not equal power.
Having seen a few more reviews the power efficiency is impressive. If you don't need the absolute fastest an under volted chip could be very nice.
yea it equals heat
75c is 75c it doesn't matter how many watts it isRight but you won't heat your room more because the cpu is at 95 degrees vs 60 degrees. The actual wattage is what matters for heating your room.
The match analogy is correct. If a Zen 4 CPU and Intel CPU both consume 250watts, they will heat the environment up the same. The Zen 4 CPU will have a smaller CPU die to spread that wattage across hence this perception that it's 'hotter'. The fact Zen4 does more work for this power draw means it's more efficient.75c is 75c it doesn't matter how many watts it is
depends how you want to do it you can undervolt while increasing performanceHaving seen a few more reviews the power efficiency is impressive. If you don't need the absolute fastest an under volted chip could be very nice.
Basic physics disagrees with you.75c is 75c it doesn't matter how many watts it is
^ You do know that the 13900K will have double the E cores of its predecessor? Expect the two will be very close in absolute performance.
Alderlake beats it in most games as far as I can see and for $2.5 less per frameJust looking at the cross section of reviews, and it looks like the 13900K will be DOA vs 7950x for new builds, unless something magical happens to make the E-cores do a lot more work.
Another point being that the i9 will be the pinnacle of that socket and is now EOL, vs the AM5 being the first and therefore the slowest you could possibly get, but may have 3 more generations left to go.
Lower down the stack is going to be a hard choice for new builds, with parts trading blows across different scenarios. The only saving grace being the cheap B660/DDR4 if you want a short term solution, with no where to go but sideways.
7950x is barely even better than a 12700k in gaming
i read in the reviews - it doesn't go to 95 when you're gaming mate.Wow these seem bad, barely competitive with alderlake and you can turn your heating off in the winter
12700k is looking like it was a super good purchase![]()
yea chart doesn't say it does says 75c in cyberpunki read in the reviews - it doesn't go to 95 when you're gaming mate.![]()
Yes, because all the world cares about is gaming.
7950X is outselling the others by a considerable margin, over 100 sold already, because yep these top-end CPU's are also great for none gaming stuff too.![]()
