Well you are, whether you see it or not. If you don't see any alternatives then you're obviously not looking, probably because you're all in and don't want to look at the alternatives.
Obviously you wouldn't have read it as you've only come back to these forums after a four month hiatus because, one would assume, the news that the party you support has screwed things up so badly, however as i said in another thread the solution is simple. You tax the top 3%, maybe even implement a wealth tax on them, then you give half of what you collect to those most effected by inflation / interest rate rises while the treasury keeps the other. That way you protect the most vulnerable while also increasing the value of your currency and countering inflation, you work with your central bank rather than working against them.
