I hope you are not paying £45 for a 5kg gas refill.
The price at the start of the year was £17/18 for a refill.
Edit: you get 20%-70% of it back depending on how long you have had it and you need to to have the paperwork to hand.
No paperwork.Will adding a door cause any problems with air circulation etc? Reason I ask is there is no ventilation on that (if it is a Koda clone)Got an upgrade to my pizza oven just before the royal funeral. Wasn't intending to get one, but hey ho...
Tesco had the ottimo 12" Gas Pizza oven on sale (end of season type thing) for £125 and we had some vouchers too. Sub £100 pizza oven? Yes please. It's a complete clone of the Koda tbh. Only thing I've had to do is buy a longer gas hose. It came with a 60cm hose which was not long enough for me. Got a longer gas hose from a local supplier for ~£5 for 1.2m. Spent a few days locating a place that would sell me a gas bottle, surprisingly large number of places nearby will only do refills now which is awkward.
Didn't come with an instruction book. Dropped the company an email late saturday night, received a response in my inbox with a digital copy at 8:30 sunday morning. Impressive customer service.
Can't say the first pizza was a success. I left it to pre heat for 20 minutes on full blast, suspect it needed a bit longer. 2nd, 3rd and 4th were significantly better. Seems like 10-11" is the ideal size for it. Enough space to move it around easily to cook evenly. Dough wise, just used some frozen stuff by Northern Dough Co. Works nicely. Was just their normal stuff, but really want to try some of the other pizza dough's they have. Rosemary dough sounds nice for a garlic pizza. I can also recommend their cookie doughs.
Already looking at a couple of modifications. One of which is a door, just to aid heating.
Google your local propane supplier. I found them cheaper and they had more gas available than local Calor and B&QMay order the Koda 12 this weekend. So where is the general go to place for the gas? Places like b&q/garden centres?
Just want to weigh up the cost of using the thing against how much I will actually be using it![]()
I'll have a look. Noticing many places aren't offering bottles themselves right now so that could be a challenge but will see.Google your local propane supplier. I found them cheaper and they had more gas available than local Calor and B&Q
As long as you ask for Patio gas, you will be fine.
5kg, ballpark , good for 50 pizzas I reckon. Mebbe more
That's more than I was expecting tbh, not bad at all. What we thinking approx 10-15 min to reach temp, few minutes per?
Now... Is it frowned upon to use premade frozen dough balls as a introduction/practice
Yeah I'll definitely be having a go at itI have used premade balls before. They were "ok", but its pretty easy to make your own dough.
Might be useful if you had a wood fired one I guess.Probably cooked near 100 pizzas now and never felt I needed a temperature gun.Might be useful if you had a wood fired one I guess.
5KG will be a very good start that is for sureI'll have a look. Noticing many places aren't offering bottles themselves right now so that could be a challenge but will see.
I'm assuming 5kg will be good, how long would that last as a rough guess?
*Hadn't crossed my mind until just now but we use a gas supplier at work for our fabrication work shop for their welders etc. I'll see if they offer patio gas and maybe get it through them!
Depending on how many pizzas you cook in one batch etc and how often, I guess 5KG should last you quite a few months if you do a decent batch. I guess where you can fall foul is if you say do one pizza one day then another another etc. You will use quite a lot heating up the oven just for one pizza. I hope you are not paying £45 for a 5kg gas refill.
