Caporegime
- 13 May 2003
- Warwickshire
We need Rachel Riley. And perhaps while she's here she can help us solve this maths problem.
Question e? Or question d?It's just question e
Oops. Yes I mean d.Question e? Or question d?
The only way I get 4 from 6, 5, 4,3 is :
6+5 = 11
-4-3 = -7
11-7 = 4
(6-5)-(4-3)?
Edit no that's not right oops. You sure the questions right?
If it is that, that's terrible. Maths solver comes up with an error if you don't specify the actual 0.6-5-(4-3)=4()
Error: Cannot parse
6-5-(4-3)=4()
That won't be the right answer, but I think it's technically correct.If it is that, that's terrible. Maths solver comes up with an error if you don't specify the actual 0.
Absolutely. We've put that in the homework book.That won't be the right answer, but I think it's technically correct.
Isn't 6(-)5 equal to 6*-5 = -30 ?At least putting the following in Wolfram Alpha gives 4
6(-)5-(4-3)=4
Yes, that's cheating, but I suspect the question is broken.. surely you should get merit marks for bucking the system![]()
Yes - if you change the sign - so why?Can you take the 4 from the right side over to the left side?
You can, but you can't leave it there as well. The question is to make it work by just adding brackets.Can you take the 4 from the right side over to the left side?
Can you take a photo of the question sheet/section of the textbook or whatever on your phone and post pls? (upload to imgur)
It's just question d. He's already got all the rest.
Just tell him to put. 4 is the wrong answer. should be -6Can you solve this by just adding brackets?
6-5-4-3=4.
Honestly, it's bad when I can't even help my 11 year old with his homework.![]()
6-5-4-3=4.
He will be top of the class.He's got the answer provided by touch written down, which resolves both sides of the equation to 0.I was going to say a mathematician will figure this out, but they expect an 11 year old to do this?
Just say no brackets are required. The numbers look level enough?He will be top of the class.
